You guys have to read, that means the entire thread.....I never knew how to do this other than simple copy/paste...I had to read all the info..all the mistakes and tidbits and pitfalls people went through. Most people wont hand feed when the info is in the thread...I had to read and now I have to find the info for YOU...cmon...STOP BEING LAZY.
Everytime I check this thread someone wants a handout...read...then read it again..read other threads so you get the info..slang....lingo...technical terms people are using.
The first spoiler has the file....pick the correct one for your application
http://avic411.com/index.php?/topic/81468-the-avic-development-mod/?p=337784
Follow the instructs, that will patch the nav software open to accept the changes.
NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE!
Instruction to install patch
- Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
- Unpack/unrar downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working). POWER unit
- Your device will reboot into testmode.
- Select Write program forcedly => Copy Script, script will patch your system( IT wont say you correctly applied ANYTHING...it will simply reboot.
- Remove USB stick after script finishes.
All that file does is get you into testmode, the script is a diff operation...you enable the script
(4. Select Write program forcedly => Copy Script, script will patch your system and reboot.)
which patch's the nav software.
Loading Map files:
I took the same USB with the same files on it and added the new map files in the matching folders....( YES you create the folders and sub folders)...that the files will go into
on the unit( so I can remember where they go).
http://www.gpspower.net/igo-tutorials/304319-where-put-igo-different-files.html
I also created a folder called Backup on the usb
So once again-
- insert stick into USB1 (USB2 isn't working).
- NOTICE.....your not applying any script or patch
- Using the built in file manager-> Linux Root-->extdata-->iGO...I copied the license and contents folders off my unit and pasted into my Backup folder on the usb.(patience this can take some time)
- You likely( I cant rem) wont get some pretty notice that everything copied.....make sure..dig around and check it out
- Once your sure they are backed up...go back into the license and contents folders on the unit and into the sub folders and delete the files your going to replace..FILES...NOT SUB FOLDERS
- Now you go to those exactly named folders and sub folders on the usb and copy/move the contents onto the unit in the coresponding correct folders and sub folders.
- Patience...wait for it to fin...might take 5 mins..maybe 20 mins
Now if this is all to much for you...dont try it.
NEX 8000
the problem is this makes no mention mention of the avic2usb and usb2avic scripts, doesnt tell you how to use them and doesnt tell you they are going to be needed. thats why so many are having issues. theres missing information.
i didnt know that either and tried to use usb2avic, because all i wanted to do is copy the damn files from my usb to the unit and be done with it. now there is no igo folder in the unit. so now i need to make an igo folder on the usb and i need someone to tell me what was in the units original igo folder so i can put all that in and try again. its frustrating as hell. the older units ran on windows and it was incredibly easy, but with this one the simple cop and paste method of using a computer does not work and you need this script and that script and all this other stuff. no one seems to understand that frustration at all.
can someone please tell me the exact contents of the igo folder on the unit so i can try this again?
