Actually you can. I installed nova launcher and other stuff no problem. Again there are two things, no usb wifi support and you have to have warp disabled.
hi can you tell me how to install the nova or any map softwer like sygic on 8100 nex
thanks
thanks
You guys have to read, that means the entire thread.....I never knew how to do this other than simple copy/paste...I had to read all the info..all the mistakes and tidbits and pitfalls people went through. Most people wont hand feed when the info is in the thread...I had to read and now I have to find the info for YOU...cmon...STOP BEING LAZY.
Everytime I check this thread someone wants a handout...read...then read it again..read other threads so you get the info..slang....lingo...technical terms people are using.
The first spoiler has the file....pick the correct one for your application
http://avic411.com/index.php?/topic/81468-the-avic-development-mod/?p=337784
Follow the instructs, that will patch the nav software open to accept the changes.
NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE!
Instruction to install patch
- Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
- Unpack/unrar downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working). POWER unit
- Your device will reboot into testmode.
- Select Write program forcedly => Copy Script, script will patch your system( IT wont say you correctly applied ANYTHING...it will simply reboot.
- Remove USB stick after script finishes.
All that file does is get you into testmode, the script is a diff operation...you enable the script
(4. Select Write program forcedly => Copy Script, script will patch your system and reboot.)
which patch's the nav software.
Loading Map files:
I took the same USB with the same files on it and added the new map files in the matching folders....( YES you create the folders and sub folders)...that the files will go into
on the unit( so I can remember where they go).
http://www.gpspower.net/igo-tutorials/304319-where-put-igo-different-files.html
I also created a folder called Backup on the usb
So once again-
- insert stick into USB1 (USB2 isn't working).
- NOTICE.....your not applying any script or patch
- Using the built in file manager-> Linux Root-->extdata-->iGO...I copied the license and contents folders off my unit and pasted into my Backup folder on the usb.(patience this can take some time)
- You likely( I cant rem) wont get some pretty notice that everything copied.....make sure..dig around and check it out
- Once your sure they are backed up...go back into the license and contents folders on the unit and into the sub folders and delete the files your going to replace..FILES...NOT SUB FOLDERS
- Now you go to those exactly named folders and sub folders on the usb and copy/move the contents onto the unit in the coresponding correct folders and sub folders.
- Patience...wait for it to fin...might take 5 mins..maybe 20 mins
Now if this is all to much for you...dont try it.
NEX 8000
I just want to confirm that this method worked for me.
I am using an 8100NEX and I successfully managed to update my maps, 3D buildings, and POI to the latest HERE versions (2015 Q3)
A later reply (I believe it is #378) also broke down which replies in the thread are most needed.
Here is a recap based on my experience:
1. Download and extract the necessary flash/update script for your AVIC head unit (reply #138), and copy all necessary files to a USB flash drive (recommended 16GB or more, so that you can backup everything). Boot your head unit with the updated USB flash drive in USB1. Select USB1 as your source and the system will reboot. As described above, from the menu that appears, you should select "Write Program Forcedly" and COPY SCRIPT. (do not use COPY DEVICE for any reason). This step is necessary to patch your maps so that they will accept any license.
2. Acquire the necessary update files from GPSPower (#207). Suggested that once you have all the Map, 3D, and POI files, that you organize them accordingly in folders on your USB drive.
Here are the places where files go by their extension.
FTR> Truck Info > /Content/MAP
FPA> Point addressing > /Content/MAP
FDA> Driver Alerts > /Content/MAP
FBL> Actual Maps > /Content/MAP
HNR> Defined Routes > /Content/MAP
3DC> 3D Buildings > /Content/Building
3DL> 3D Landmarks > /Content/Building
PHR or PH> Reporting street names > /Content/Phoneme
DEM> Landscape > /Content/DEM
POI> Points of Interest > /Content/POI
FJV> Junction view > /Content/MAP
KML> Custom Points of Interest > /Content/Userdata/POI
SPE&SPC> Speed camera files > Content\Speedcam
SKIN>SKINS >Content\skin
UX ADDONs> iGO\ux or SDcard\iGO\ux
Speedcam.txt> Speed camera files > Content/Speedcam
SpeedcamUpdates.spud> Speed camera files > Content/Speedcam
FSP (File .Speed.Profiles).Content\MAP.
KML - (Custom ITINERARY) iGO/content/userdata/route
SPC - Speed Camera files - content/speedcam
For example, on my flash drive, there is a folder called "updates". In that folder there are two folders: content and license.
The "license" folder has the necessary ".lyc" files to use with the new maps.
In the "content" folder there are three folders: "map", "poi", and "building", in which I placed appropriate map, building, and POI files from the new map set.
3 (optional). Using the file manager feature of the "Test Mode" that launches with your newly-formatted USB flash drive, I copied the "content" and "license" folders from Linux Root\extdata\iGO to a folder on my USB drive called "backup". I then made sure to check the content that was on the flash drive before doing anything further. If you feel you are missing files, go into the folder, use the "All" function, "copy", and paste them by navigating back to your desired directory in File Manager, and using the "paste" function just to make sure.
4. Using the File Manager, I went into the folders I needed to update map files (iGO/content/MAP, iGO/content/building, iGO/content/POI) and deleted all files. I did not delete license files, only copied and pasted the new ones I had acquired for the new maps into the iGO/license folder.
5. Using the File Manager, I copied the updates/content/MAP, updates/content/building, and updates/content/POI using the "All" > "Copy" functions, folder by folder (I did MAP last as it had the most/largest files) to the corresponding folders on extdata/iGO on Linux Root.
6. I turned off the car/unit, restarted the system and verified by going into the MAP function of the head unit that the new maps were copied and everything was working.
Good thing that I saw this -- updating AVIC maps are not nearly as easy as updating Garmin systems on a Kenwood but I'm glad that this was even possible.
List of needed files for HERE NA 2015Q2
\iGO\license\Pioneer_LMG_for_North_America_SKU_2004688_2015_Q2.lyc \iGO\license\Pioneer_maps_for_North_America_SKU_2004688_FACTORY_PKG_2013_Q2.lyc \iGO\license\Pioneer_NF_UC_13Q2_NQ_ExtPOI_TMC_3D_DEM_HNR_TTS_JV_CAR_CS_NG_SAR_High_NX263A_NX263A.lyc \iGO\license\United_States_Canada_NQ_Primo_2015_Q2.lyc \iGO\content\building\Canada_HERE_2015.Q2_150608.3dl \iGO\content\building\Canada_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Alabama_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Alaska_HERE_2015.Q1_150415.3dc \iGO\content\building\USA_Alaska_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Arizona_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Arizona_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Arkansas_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_California_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_California_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Colorado_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Colorado_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Connecticut_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Connecticut_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Delaware_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_District_of_Columbia_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_District_of_Columbia_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Florida_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Florida_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Georgia_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Georgia_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Hawaii_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Hawaii_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Idaho_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Illinois_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Illinois_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Indiana_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Indiana_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Iowa_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Kansas_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Kentucky_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Kentucky_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Louisiana_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Louisiana_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Maine_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Maryland_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Maryland_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Massachusetts_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Massachusetts_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Michigan_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Michigan_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Minnesota_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Minnesota_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Mississippi_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Missouri_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Missouri_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Montana_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Nebraska_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Nevada_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Nevada_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_New_Hampshire_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_New_Jersey_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_New_Jersey_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_New_Mexico_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_New_York_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_New_York_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_North_Carolina_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_North_Carolina_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_North_Dakota_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Ohio_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Ohio_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Oklahoma_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Oregon_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Oregon_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Pennsylvania_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Pennsylvania_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Puerto_Rico_HERE_2015.Q1_150415.3dc \iGO\content\building\USA_Rhode_Island_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Rhode_Island_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_South_Carolina_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_South_Dakota_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Tennessee_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Tennessee_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Texas_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Texas_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Utah_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Vermont_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Virginia_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Virginia_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Washington_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Washington_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_West_Virginia_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Wisconsin_HERE_2015.Q2_150608.3dl \iGO\content\building\USA_Wisconsin_HERE_2015.Q2_150724.3dc \iGO\content\building\USA_Wyoming_HERE_2015.Q2_150608.3dl \iGO\content\dem\Basemap_Eurasia_CGIAR_2006.06_120920.dem \iGO\content\dem\Basemap_SouthAmerica_CGIAR_2006.06_150701.dem \iGO\content\dem\BasemapAfricaCGIAR_2006.06_081013.dem \iGO\content\dem\BasemapNorth_AmericaCGIAR_2006.06_081103.dem \iGO\content\dem\BasemapOceaniaCGIAR_2006.06_081013.dem \iGO\content\dem\Canada_CGIAR_Premium_2006.06_090312.dem \iGO\content\dem\USA_CGIAR_Premium_2006.06_090313.dem \iGO\content\map\Basemap_NNG_2012.03_151015.fbl \iGO\content\map\Canada_HERE_2015.Q2_150723.fbl \iGO\content\map\USA_Alabama_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Alaska_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Arizona_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Arkansas_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_California_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Colorado_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Connecticut_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Delaware_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_District_of_Columbia_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Florida_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Georgia_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Hawaii_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Idaho_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Illinois_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Indiana_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Iowa_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Kansas_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Kentucky_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Louisiana_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Maine_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Maryland_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Massachusetts_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Michigan_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Minnesota_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Mississippi_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Missouri_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Montana_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Nebraska_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Nevada_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_New_Hampshire_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_New_Jersey_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_New_Mexico_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_New_York_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_North_Carolina_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_North_Dakota_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Ohio_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Oklahoma_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Oregon_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Pennsylvania_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Puerto_Rico_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Rhode_Island_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_South_Carolina_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_South_Dakota_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Tennessee_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Texas_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Utah_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Vermont_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Virgin_Islands_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Virginia_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Washington_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_West_Virginia_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Wisconsin_HERE_2015.Q2_150925.fbl \iGO\content\map\USA_Wyoming_HERE_2015.Q2_150925.fbl \iGO\content\map\Canada_HERE_2015.Q2_150723.fda \iGO\content\map\USA_Alabama_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Alaska_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Arizona_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Arkansas_HERE_2015.Q2_150925.fda \iGO\content\map\USA_California_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Colorado_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Connecticut_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Delaware_HERE_2015.Q2_150925.fda \iGO\content\map\USA_District_of_Columbia_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Florida_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Georgia_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Hawaii_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Idaho_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Illinois_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Indiana_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Iowa_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Kansas_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Kentucky_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Louisiana_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Maine_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Maryland_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Massachusetts_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Michigan_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Minnesota_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Mississippi_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Missouri_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Montana_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Nebraska_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Nevada_HERE_2015.Q2_150925.fda \iGO\content\map\USA_New_Hampshire_HERE_2015.Q2_150925.fda \iGO\content\map\USA_New_Jersey_HERE_2015.Q2_150925.fda \iGO\content\map\USA_New_Mexico_HERE_2015.Q2_150925.fda \iGO\content\map\USA_New_York_HERE_2015.Q2_150925.fda \iGO\content\map\USA_North_Carolina_HERE_2015.Q2_150925.fda \iGO\content\map\USA_North_Dakota_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Ohio_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Oklahoma_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Oregon_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Pennsylvania_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Puerto_Rico_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Rhode_Island_HERE_2015.Q2_150925.fda \iGO\content\map\USA_South_Carolina_HERE_2015.Q2_150925.fda \iGO\content\map\USA_South_Dakota_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Tennessee_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Texas_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Utah_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Vermont_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Virginia_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Wisconsin_HERE_2015.Q2_150925.fda \iGO\content\map\USA_Wyoming_HERE_2015.Q2_150925.fda \iGO\content\map\Canada_HERE_2015.Q2_150723.fjw \iGO\content\map\USA_Alabama_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Arizona_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Arkansas_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_California_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Colorado_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Connecticut_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Delaware_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_District_of_Columbia_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Florida_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Georgia_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Hawaii_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Idaho_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Illinois_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Indiana_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Iowa_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Kansas_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Kentucky_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Louisiana_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Maine_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Maryland_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Massachusetts_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Michigan_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Minnesota_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Mississippi_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Missouri_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Montana_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Nebraska_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Nevada_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_New_Hampshire_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_New_Jersey_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_New_Mexico_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_New_York_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_North_Carolina_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_North_Dakota_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Ohio_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Oklahoma_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Oregon_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Pennsylvania_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Puerto_Rico_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Rhode_Island_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_South_Carolina_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_South_Dakota_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Tennessee_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Texas_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Utah_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Vermont_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Virginia_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Washington_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_West_Virginia_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Wisconsin_HERE_2015.Q2_150925.fjw \iGO\content\map\USA_Wyoming_HERE_2015.Q2_150925.fjw \iGO\content\map\Canada_HERE_2015.Q2_150723.fpa \iGO\content\map\USA_Washington_83_TomTom_2014.03_140620_(AP).fpa \iGO\content\map\USA_West_Virginia_83_TomTom_2014.03_140620_(AP).fpa \iGO\content\map\Canada_HERE_2015.Q2_150723.fsp \iGO\content\map\USA_Alabama_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Alaska_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Arizona_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Arkansas_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_California_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Colorado_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Connecticut_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Delaware_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_District_of_Columbia_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Florida_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Georgia_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Hawaii_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Idaho_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Illinois_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Indiana_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Iowa_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Kansas_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Kentucky_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Louisiana_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Maine_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Maryland_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Massachusetts_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Michigan_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Minnesota_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Mississippi_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Missouri_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Montana_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Nebraska_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Nevada_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_New_Hampshire_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_New_Jersey_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_New_Mexico_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_New_York_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_North_Carolina_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_North_Dakota_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Ohio_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Oklahoma_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Oregon_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Pennsylvania_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Puerto_Rico_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Rhode_Island_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_South_Carolina_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_South_Dakota_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Tennessee_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Texas_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Utah_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Vermont_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Virginia_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Wisconsin_HERE_2015.Q2_150925.fsp \iGO\content\map\USA_Wyoming_HERE_2015.Q2_150925.fsp \iGO\content\map\North_America_HERE_Easy_2015.Q2_150925_(V2).hnr \iGO\content\map\North_America_HERE_Fast_2015.Q2_150925_(V2).hnr \iGO\content\map\North_America_HERE_Green_2015.Q2_150925_(V2).hnr \iGO\content\map\North_America_HERE_Short_2015.Q2_150925_(V2).hnr \iGO\content\poi\Canada_HERE_2015.Q2_150608.poi \iGO\content\poi\Canada_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Alabama_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Alabama_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Alaska_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Alaska_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Arizona_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Arizona_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Arkansas_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Arkansas_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_California_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_California_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Colorado_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Colorado_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Connecticut_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Connecticut_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Delaware_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Delaware_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_District_of_Columbia_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_District_of_Columbia_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Florida_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Florida_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Georgia_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Georgia_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Hawaii_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Hawaii_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Idaho_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Idaho_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Illinois_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Illinois_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Indiana_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Indiana_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Iowa_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Iowa_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Kansas_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Kansas_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Kentucky_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Kentucky_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Louisiana_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Louisiana_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Maine_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Maine_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Maryland_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Maryland_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Massachusetts_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Massachusetts_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Michigan_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Michigan_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Minnesota_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Minnesota_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Mississippi_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Mississippi_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Missouri_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Missouri_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Montana_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Montana_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Nebraska_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Nebraska_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Nevada_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Nevada_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_New_Hampshire_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_New_Hampshire_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_New_Jersey_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_New_Jersey_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_New_Mexico_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_New_Mexico_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_New_York_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_New_York_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_North_Carolina_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_North_Carolina_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_North_Dakota_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_North_Dakota_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Ohio_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Ohio_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Oklahoma_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Oklahoma_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Oregon_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Oregon_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Pennsylvania_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Pennsylvania_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Puerto_Rico_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Puerto_Rico_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Rhode_Island_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Rhode_Island_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_South_Carolina_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_South_Carolina_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_South_Dakota_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_South_Dakota_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Tennessee_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Tennessee_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Texas_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Texas_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Utah_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Utah_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Vermont_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Vermont_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Virgin_Islands_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Virgin_Islands_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Virginia_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Virginia_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Washington_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Washington_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_West_Virginia_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_West_Virginia_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Wisconsin_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Wisconsin_HERE_Extended_2015.Q2_150611.poi \iGO\content\poi\USA_Wyoming_HERE_2015.Q2_150925.poi \iGO\content\poi\USA_Wyoming_HERE_Extended_2015.Q2_150611.poi \iGO\content\tmc\Canada_Clear_channel.tmc \iGO\content\tmc\USA_Clear_channel.tmc
Here you can download maps you need: - http://www.gpspower.net/igo-maps/337749-north-america-here-2015-q2.html
Here you can download licenses you need: - http://www.gpspower.net/igo-software-tools/286996-collection-licences-igo.html
script to copy files
manual_map_update_for_AVICx60x70.zip
pass: 4pda
Ask all questions about maps and licenses here:
Well i have an AVIC-F60DAB. I tried to use the script from above. But there was only a message File Error. Now the complete port1 is ignored. Also my iphone isnt workin anymore. just over bluetooth.
Hey guys. I am trying to get my AVH-4200 into testmode. I have generated the file using the perl script from github like so:
perl encode.pl 007SERVICE003ALL00833333333007SERVICE0082013010100820201230000 TESTMODE_A.KEY
I then placed it in root of USB drive and plugged into unit and turned it on. It still doesn't boot into testmode. I also tried renaming it to TESTMODE.KEY and also again by making it all lower case on both names. I have also tried both USB ports. Nothing.
Am I missing something or is the procedure or string different for the 4200. Ive also tried a few different testmode.key files i googled and found here but still not working. Any help would be appreciated.
Hello,
If i use the initial hack and copy everything to a USB stick will this actually change anything on my head unit?
I have a fully licensed copy at the moment and want to add speed cameras to it. Am i able just to add these to my licensed copy?
The 4200 hasn't been patched yet, only the x000 with FW 1.07, 1.08 and 1.11 and the x100 with FW 1.05
TTS available in languages.You can add any language from the listrussianenglish - 2 version EU and USfrench - 2 version EU and USspanish - 2 version EU and USdutchdanishgermanitalianpolishportugueseturkish
Swedish seems not to be available. Is there any other Swedish TTS file that can be used (iGO)? Or possible to make one?
only
sys.pioneer.misc.navi_pl_cation=sys.pioneer.navi_pl_on
Add to build.prop file.
This is for older generation of nex devices (F60/F960/x000NEX).
System is checking this android property before showing this navigation caution OK screen, so setting this property to "already shown" state disables screen at all.
Excuse a noob question, can the build.prop file be overwritten, after copying and changing it or how is it done?
You can do this in different ways. You can mount /system as read-write and append line to file or overwrite file using copyscript or UART console. You can also mount internal sdcard using your PC and edit file directly.
Yo dawgs, da CASUAL-Dev site keeps going down. I asked my boy Adam Outler to host it somewhere else and he just erected the web service "CustomizeBSP" over at jenkins.adamoutler.com. Da job is right here fo shizzle: https://jenkins.adamoutler.com/job/Customize%20BSP/
followed all instrustions but when i past my canada.fbl back over to content/map i get an error "failed to paste" any ideas ?
No free space, invalid file name, no rights to save file?
Not sure it just says failed to paste
I made just an empty folder and tried to paste that and no luck..
But now my Hu says please insert your SD card containing igo content files.
So I'm trying to find a way to get igo Ba k on my Hu Avic 8100nex firmware 1.05 I tried flashing firmware again from pioneer but same error.
https://mega.nz/#!eNg0TI6D!_FWOYJV3zPJzx6NcRp6fJu6TVAjzv16xWJOox9qIEhA
Has anyone had success with an exFAT formatted USB vice FAT32?
Found a 16gb stick and applied the patch & updated to US Q3. Thanks much! Question though, when I checked the map info area on the unit, the "ftr" Truck? files listed are not activated/dimmed. Not sure if it's always been that way, but should these be active? I copied the appropriate licence files into the license folder, but nothing specific to "ftr"
Any ideas?
Thanks again for this great tool.
For truck info you need another license file. Seems like this info is only useful for truck drivers.
Thanks WhatIs.
Hmmm... Obviously I don't have all licenses. Missing the Q3 address points as well. I used the most recent lyc from GPSPower, anyone know the file names required? 8100, I left the license folder in tact and just pasted the additional lyc. Thanks
For those interested, looks like some unneeded files as well..
Point Addressing (.fpa) PRIMO ONLY!
These files help you navigate to addresses that are off the main street, Not available for every region.
Primo\Content\Map\
*.fpa only Canada
No need to open or dismount unit. Just write image for your unit into usb stick or sd card (please do not copy img file, use image writer software), and use test mode "copy device" key to enter recovery mode and write contents of your external usb/sd card into internal sd card.
UPD: you can download avic 5000 nex image from Adam's website: https://builds.casual-dev.com/index.php?dir=random%2FAVIC%2F
Hi, First of all thanks for all the good work. I tried checking the website mentioned in your post in order to download image for 5000 nex but it seems to be unavailable. Request you to please let me know in case you are aware if this is posted some where else as well.
