The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 6 of 29
Posted Dec 28, 2015 · 08:57 UTC#126
шикаааарно ответил ))))
Posted Dec 28, 2015 · 20:15 UTC#127
Ищем владельцев SPH-DA120 Ð´Ð»Ñ Ð¿Ð¾Ð¿Ñ‹Ñ‚ÐºÐ¸ переделки в F960BT!
some  russian jerk have headache... :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Edited Dec 28, 2015 by Lucca
Posted Dec 28, 2015 · 20:50 UTC#128
Ok what is the deal with all the bickering and insults going back and forth between you. I don't know how this crap got started but I'm tired of it and will lock this thread if it continues. This is not the place for you to settle your differences.
Posted Dec 28, 2015 · 20:58 UTC#129
oh so Sorry,I'm deleting...,btw wondering about so strong ru-support .. Tnx
Posted Dec 28, 2015 · 21:42 UTC#130
Anybody have solution for 1.11 firmware?
How to make map update like Lucca did?
Posted Dec 28, 2015 · 21:57 UTC#131
Lucca did not do anything. Only screenshots)
Once we did it! The result can be read here http://avic411.com/index.php?/topic/81824-igo-is-fully-cracked-now/
while only for FW 1.07
Edited Dec 28, 2015 by asd255
Posted Dec 28, 2015 · 22:25 UTC#132
Dear Kura! Please kindly ask the quoted user below to post here "HIS" solution... :shock::-P:shock::-P :-P :-P :-P :-P :-P
Posted Jan 02, 2016 · 16:04 UTC#133
Simple question that someone can hopefully add to the FAQ:
I have a 6000NEX, which is one of the models with a microSD slot on the face.
Given the process(es) we have at present, would it be possible to be able to run any mods without having to open the unit to access the internal SD?  I saw some comments about being able to run your own ROM from an external card.
If not, are there any notable precautions (delicate ribbon cables, etc) to take, or helpful hints to follow when opening the unit; or is it just as intuitive as opening any other device?
Thanks.
Oh, one other concern, in case anyone knows: I've been trying to hit jenkins.casual-dev.com for a few days now.  Is it down indefinitely?
Posted Jan 02, 2016 · 16:33 UTC#134
Yes, it is possible. You can do almost everything without dismounting unit. In case of problems (bricked device) you can simply revert changes by restoring device from full sd card backup (copy device in testmode).
Posted Jan 06, 2016 · 23:22 UTC#135
So what option(s) in the BSP do you set to convince the unit to boot from the external SD card (the slot on the front)?
Posted Jan 08, 2016 · 10:58 UTC#136
It seems that I misunderstood you. I just said that firmware can be modified (and reverted to original state) without removing the device and without accessing to internal sd card. You can do almost everything without dismounting device.
I think you can also modify bootloader boot options or boot partition settings to load from external sd, but this is much more complicated thing and I can not help you with this modification.
Posted Jan 09, 2016 · 13:27 UTC#137
Root your unite & have fun! :wink:
Regards,
Lucca
Posted Jan 11, 2016 · 16:26 UTC#138
patched navigation software (iGO NextGen)
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
You can copy manually content and licenses through File Manager, using copy_script or by inserting internal sd card into your PC.
Don't forget to set proper filesystem rights to newly copied files.
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB)  FW 1.07/1.08
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB) FW 1.11/1.13/1.14/1.15 - iGO ver: 9.18.28.610126
 -  x100(5100-8100NEX F970BT/DAB/TV F70/77DAB)  FW 1.05/1.07/1.10 - iGO ver: 9.18.28.610130
-  x200(AVIC-x200NEX/AVIC-Fx8x )  FW 1.00/1.02/1.07 - iGO ber: 9.18.28.624842
Use latest winrar5 http://www.rarlab.com/download.htm
For 5000nex-7000nex and 5100nex-7100nex users it is possible to add all features of 8000nex/8100nex:
  • 3D Landmarks,
  • 3D City Map,
  • Natural Voice Guidance,
  • Enhanced Junction View & Realistic Road Signs,
  • Free Lifetime Traffic by Total Traffic Network
Instruction to install patch
  • Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
  • Unpack downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
  • Your device will reboot into testmode.
  • Select Write program forcedly => Copy Script, script will patch your system and reboot.
  • Remove USB stick after script finishes.
Now you have have cracked version of maps software. This version will accept any valid licenses, even licenses not for your device.
You can find new content and licenses using gpspower.net or 4pda.ru:
http://www.gpspower.net/igo-maps.html
http://4pda.ru/forum/index.php?showtopic=141926
Adding RDS-TMC for the 5000/5100 NEX
pass: 4pda
  • Download file
Adding TTS languages
Is available in 16 TTS languages
You can add any of the available languages
TTS download files you can on 4pda
http://4pda.ru/forum/index.php?showtopic=200728&view=findpost&p=46123907
dan.dnk.naja
deu.deu.hans
eng.gbr.amy
eng.usa.salli
fra.can.chantal
fra.fra.celine
ita.ita.carla
nld.nld.ruben
pol.pol.jan
por.bra.vitoria
por.prt.cristiano
rus.rus.tatyana
rus.rus.maxim
spa.esp.conchita
spa.usa.penelope
tur.tur.filiz
if you need the latest information
you can get it on 4pda.ru - rus lang
http://4pda.ru/forum/index.php?showtopic=698751
Edited May 04, 2018 by asd255
Posted Jan 11, 2016 · 17:24 UTC#139
Wow. Thank you. Is it now possible to get rid of this warning?
And wich maps must i take to get them working on my F70DAB?
Thank you very much.
Posted Jan 11, 2016 · 18:24 UTC#140
asd255, Thanks so much for the contribution!!! Does your map license crack turn WARP off?
Posted Jan 11, 2016 · 21:36 UTC#141
You can use this patch with WARP enabled
Posted Jan 11, 2016 · 21:44 UTC#142
Please read information about content and licenses in appropriate forums. Sorry, I cannot help you with maps and licenses.
asdasd
[spoiler=log] [/spoiler]
Posted Jan 12, 2016 · 06:43 UTC#143
Good work guys :)
Can you write tutorial how to update maps and licences once we got them?
What does it mean that there is possibility to unlock additional features in NEX5000 ( F960BT ). How to do it?
What about this free traffic service?
Posted Jan 12, 2016 · 18:04 UTC#144
I have downloaded the .rar file for the F77DAB-radio, but when I try to unpack the file I get an error message, saying that "the file is not a valid archive".
Has anyone succesfully downloaded and unpacked the file?
Posted Jan 12, 2016 · 18:16 UTC#145
The same here
Posted Jan 12, 2016 · 18:21 UTC#146
The same here
Use WinRar 5.x or later... ;)
Posted Jan 12, 2016 · 18:41 UTC#147
Thanks, did the trick 8)
Posted Jan 12, 2016 · 19:08 UTC#148
Just upload content into corresponding folders. Maps (*.fbl) into /extdata/iGO/content/maps, POI (*.poi) into /extdata/iGO/content/poi and so on. Put your licenses into /extdata/iGO/license/
You can copy files from your USB stick using testmode's file manager. Copy files from USB and paste them into extdata subfolders of storage sd.
Don't forget to set linux filesystem rights using something like this:
#!/system/bin/sh
chmod -R 777 /extdata/iGO/*
For example, you can upload corresponding content (3dl or 3dc files + licenses) to enable missing 3D buildings feature.
Edited Jan 12, 2016 by asd255
Posted Jan 13, 2016 · 19:59 UTC#149
What's the advantage for 8000-NEX users?  It sounds like I can get map updates for ... cheaper shall we say?
Is there anything else that would be available that is not currently available?
Posted Jan 13, 2016 · 22:24 UTC#150
Nex8000 and 8100 users have more licenses  and contents like 3d cities
Page 6 of 29
