2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 3 of 32
Posted Aug 24, 2015 · 18:13 UTC#51
Flomsen, can you please PM me the password for the zip file,I will greatly appreciate,thank you for sharing the file
Posted Aug 24, 2015 · 18:18 UTC#52
Hi, can you please send me the password? Thank You
Posted Aug 24, 2015 · 19:36 UTC#53
hello, I could please have the password for the zip file per PM? I will greatly appreciate, thank you for sharing the file
Posted Aug 25, 2015 · 07:43 UTC#54
May i have It 2
Posted Aug 25, 2015 · 08:07 UTC#55
Flomsen, Can you send me the password too?
PS. I already have Dropbox installed and registered... Sorry ;)
Posted Aug 25, 2015 · 08:11 UTC#56
Can one get the cards to run on the AVIC-F20BT tell me how I? Can I pick up the CARDINFO.cif and VERINFO.DAT from the 2013er version , does it work?
Edited Aug 25, 2015 by user1610
Posted Aug 25, 2015 · 10:52 UTC#57
 No i think he says wrong card
Posted Aug 25, 2015 · 11:12 UTC#58
1. Get testmode.key from this post: http://avic411.com/index.php?/topic/35110-avic-f40bt-testmode-fixed-firmware/?p=256194
2. Copy RenewalIFLib.dll from your unit to SD card
3. Edit RenewalIFLib.dll with a Hex Editor and replace this
03 50 a0 e3 85 00 00 ea 06 00 a0 e1
with this
00 50 a0 e3 85 00 00 ea 06 00 a0 e1
4. Copy the edited RenewalIFLib.dll back to your unit
5. Run the update and type "PASSWORDPASSWORD" when asked for password
But what exactly do you need to do with the testmode.key. What I can make out from the post is that the this Key file needs to be in the root of the SD. But I'm not certain if the rest of the upgrade files need to be there as well, or that the key file is the only file on the SD card. And the upgrade needs to be loaded from a second sd card.
Posted Aug 25, 2015 · 13:12 UTC#59
This.
But don't bother, the trick with RenewallFLib.dll does not work.
Posted Aug 25, 2015 · 14:13 UTC#60
Ok thank you.
Posted Aug 25, 2015 · 15:41 UTC#61
Update does not work for password error
Please HELP me
Navi: F940BT
Edited Aug 25, 2015 by Audi-X
Posted Aug 25, 2015 · 20:26 UTC#62
Guy's i was trying to copy my RenewalIFLib.dll from my head unit but i could not copy and paste it to my sd card.
Then i replaced the AUTHINFO.DAT and VERINFO.DAT and he was skipping the password question! YEAH
After the restart the navigation was asking about the right SD Card and he hasn't got the normal startup.
So i has to reinstall the 2013 version and i hope it will be working properly again ;)
Hope that someone will crack the 2015 version soon so that we have a lot of pleasure from it.
I'm glad that i still had the 2013 version and it's working again  :-)
Edited Aug 26, 2015 by Sjarrel
Posted Aug 26, 2015 · 12:22 UTC#63
Hi, ive got 2 f930bt units, one is a standard eu unit which Im hoping to do the 2015 update tonight (previously did the 2013 update on it). The second is a russian unit that doesn't have the port on the back for the traffic unit. I tried my previous update in it and it did nothing. Presumabley as the cardinfo file was incorrect. Does anyone have a russian update with the relavent cardinfo file or know  the correct model code for the russian units to edit the cardinfo file?
Cheers
Gav
Posted Aug 26, 2015 · 16:08 UTC#64
Confirmed update from 5.0 to 6.0 on F9220
Apply these changes to your RenewallFlib.dll on your Unit:
Offset 000019F0:  0350A0E3 replace with 0050A0E3
Offset 00001A10:  0350A0E3 replace with 0050A0E3
Offset 00001AD8:  0350A0E3 replace with 0050A0E3
Offset 00001C1C:  0250A0E3 replace with 0050A0E3
Offset 00001C24:  0150A0E3 replace with 0050A0E3
Offset 00001A3C:  0350A0E3 replace with 0050A0E3
Users with units older than F30BT will have to use cardinfo from this post:
Posted Aug 26, 2015 · 18:05 UTC#65
I've tried it, but always write: "No SD available. Insert SD to continue" and won't start  :(
What can I do?
thx
Edited Aug 26, 2015 by tipcsi
Posted Aug 26, 2015 · 19:48 UTC#66
Again many thnx monsterf9 but i'm still hoping that there would be an easier way to do this.
Let's wait for the one and only obi wan kenobi to fix this :)
Posted Aug 26, 2015 · 20:25 UTC#67
It works!
F9310BT
Thanks a million
Posted Aug 26, 2015 · 21:56 UTC#68
Thanks a lot, can you please send me the password for zip and install?
Cheers!
Posted Aug 26, 2015 · 22:15 UTC#69
f30bt works!! all good! perfect! thnx :-)
Posted Aug 26, 2015 · 22:37 UTC#70
Yeah it worked out well !!!! My first Hex editing is succesfully completed :)
monsterf9 would you explain me in pm what i have to do to make this update excepted by AVIC-F9220BT?
Thnx in advance !!!!
Edited Aug 27, 2015 by Sjarrel
Posted Aug 27, 2015 · 06:38 UTC#71
which renewallflib.dll do you edit?
the one in user\prg1\apl   or   the one in user\prg0\apl???
Posted Aug 27, 2015 · 07:52 UTC#72
Nudie
in user\prg0\apl
Posted Aug 27, 2015 · 07:58 UTC#73
Nudie
in user\prg0\apl
thx
Posted Aug 27, 2015 · 09:01 UTC#74
can someone send me the password?
Posted Aug 27, 2015 · 09:41 UTC#75
Thank you for sharing. Could you PM me the password? Thx
Page 3 of 32
