flomsem please ça you s'en me passWord thanks
2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
Thanks all, got this to work on my EU 930BT, still struggling with my russian one though!
Gav
If you read the complete forum you will read who has the password!
Hi Cell,
have you got the password?
Can you please send me it?
I asked for it but nobody replied me....
I need also the Passwort from the ZIP File
Thanks for the work.
Can someone please send me te pass for the zip file. I'll try on a European 9220BT.
BTW how does testmode.key work?
Do i have to copy this file on a empty sd card, put it in the radio, start and then copy the RenewalIFLib.dll to the sd card?
Can someone please send me the password for the zipfile? Thank you.
Confirm update on f930bt.
First I copy testmode.key onto sd.
Put in sd, boot up device. Testmode starts.
Navigate to user\prg0\apl. Copy renewallflib.dll. paste back to sd.
Take sd to pc an do the hex editing.
Paste back the edited file onto device.
Boot the device with the sd update.
When asked for password: PASSWORPASSWORD
I almost messed it up. When paste back renewallflib.dll, pasted it wrong place, then I hit delete on the apl dir.
Then the device diddent boot. No backup!! Made a new apl dir, pasted in renewallflib.dll. Diddent boot. Copied the apl dir from 2015 maps, pasted in the edited renewallflib.dll.... wola
So you update the device first with 2015 map before you did this al?
No, had the 2013 maps, and did delet the existing apl dir on the device by mistake , dident have backup.So you update the device first with 2015 map before you did this al?
I then copied the apl dir from the new downloaded 2015 map and used it as backup, luckily it worked.
Hi,
New to all of this, can I have the password for the ZIP file please, thanks in advance.
Hi all,
I can confirm this works on the F9210BT.
As per above, the process I followed was:
1. Run 'supertestmode' from a freshly formatted (FAT32) SD card.
2. Copy RenewallFlib.dll from USER\PRG0\APL to SD root.
3. Remove SD card from AVIC and edit RenewallFlib.dll as per monsterF9's guidance on a PC.
4. Insert SD card with edited RenewallFlib.dll back into AVIC.
5. Delete RenewallFLib.dll from USER\PRG0\APL on AVIC.
6. Paste edited RenewallFlib.dll from SD card into USER\PRG0\APL.
7. Remove SD card format it and copy Update, FIRMWARE and (modded) CARDINFO.cif onto it.
8. Insert SD card into AVIC and turn on ignition. Follow onscree instructions where you'll be prompted to enter a password. Enter PASSWORDPASSWORD
9. Sit back and wait for 25 minutes whilst the unit updates.
If anyone needs a hand with this, please ping me. I'm by no means an expert but after some reading, understand what's needed and how to achieve it.
Thanks to Flomsem for the SD contents and monsterF9 for putting in the work to crack the content. If you both PM me with your PayPal details, I'll send a donation to show my appreciation for your efforts.
Cheers,
Paul
gd
does somebody have the password for zip file
thanks in advance
brgrds
Well, didn't work on F940BT....
Now let's see if it works with mooded Cardinfo....
EDIT: still not accepting the Pass
Hi there,
Can anyone give me the password please???
Thanks in advance ![]()
Hello @Flomsen Would you be so kind as to pm me the password?
Also. This unit was in a used car I bought. There is no SD card in the unit at the moment. Do i need a Pioneer SD card to update this unit?
No, u need a normal empty Micro SD Card...
Oke,
Thanks. Now all i Need is the password. Anyone care to help me?
Hi Helder89,
Do u've the password ?
If is yes, please pm
thanks in advance
Hi all,
I can confirm this works on the F930BT.
Anybody can send me in PM password for zip archive please.
I've asked to flomsen but no response yet and need to test the update on F9310BT
Thx
Skip warning and nag for 2015 update?
Can I use same hex edithing like with the 2013 5.0 update?
Today I will try to do this upgrade on my AVI F930BT. I will let know how it goes....
Hi,
Hi, Anyone got the password they can PM me with? Thanks in advance
