2017 v7 US/Can Update available for Z110/120/130/140,X920/930/940
By RonS · Jul 23, 2017in Hacks/Mods💬 220 posts👁️ 72,748 views
Page 3 of 9
Posted Aug 31, 2017 · 04:29 UTC#51
I'm getting "Wrong SD card, enter new one" every time.. did i miss something? Can anyone send me a .dll file to try? Faaarrrkkk
Maybe you have format SD card to fat32.
Posted Aug 31, 2017 · 04:45 UTC#52
It boots up, enter the passwordpassword then it reboots, and then gets that error.. it wouldnt go that if it were not fat32
Edited Aug 31, 2017 by nezfotnemom
Posted Aug 31, 2017 · 12:23 UTC#53
It sounds like you modified a file on the installation SD. The only change to SD files would be to use a different CARDINFO.CIF  if necessary. I hope you didn't replace RenewallFlib.dll on the installation SD. I'd just extract the whole thing from the zip (we know its good) or use the original unmodified one you bought.
Posted Aug 31, 2017 · 15:04 UTC#54
I didnt touch anything on the install card, and got my dll from the unit :( ... Do you have a .dll you can send me to try?
Posted Aug 31, 2017 · 16:07 UTC#55
OK, I thought it blew-up while doing the install, after entering the password. So you think it is blowing-up and rebooting because the DLL is corrupt? I hope you saved the original you got off the unit.
Edited Nov 10, 2017 by RonS
Posted Aug 31, 2017 · 19:33 UTC#56
If you want, you can try this DLL. If it doesn't work, send me your original file and I'll patch it.
I have the original.. I will try yours. As for the .dll in the non-active prg, do you just leave that one how it is? i nly messed with the 1
Posted Aug 31, 2017 · 19:48 UTC#57
It shouldn't hurt to replace both. The non-active one will be overwritten during the update install.
BTW, earlier you said you were going to buy a unit off ebay.  What unit do you now have? Do you know what the current software  version is?
Edited Aug 31, 2017 by RonS
Posted Aug 31, 2017 · 19:55 UTC#58
Let me look I and see if I took a pic last night
Posted Sep 01, 2017 · 02:34 UTC#59
version is 6.0.. x940.. im going to try you dll in a few.. i think my strep or whatever it was came back... dying at work today
Posted Sep 01, 2017 · 19:46 UTC#60
I tried it with the original sd and got the same error.. going to try your dll here if i get enough strength
Posted Sep 01, 2017 · 20:06 UTC#61
If the problem is with a corrupted RenewallFlib.dll then the original 2017 SD won't fix it. When you get rested, try the one I sent (I hope you downloaded it because I deleted the attachment from the post. It had about a dozen downloads, but I didn't want everyone using it.  I didn't want dozens of babies crying if it didn't work.
If you have success I'll post it for everyone. If not, zip-up your original DLL and post it.
Posted Sep 01, 2017 · 22:31 UTC#62
yea i grqbbed it.. will keep you posted. thnx
Posted Sep 02, 2017 · 01:40 UTC#63
Hey guys, I have a question. I have a z140. That I have hackmode on. But I got supertest and booted into test mode. I made a back up and put it on my comp. Then copied from the HU the renewall file and used hxd to change the hex to what the instructions specified. And installed it back on the HU. Then using a separate SD with the unzipped updated map file, put it in my HU and it's not recognizing the SD. No option to update or anything. I even tried switching the cardinfo.cif file and still nothing. The stereo and everything works. But won't read the SD. Any ideas as to why?
Posted Sep 02, 2017 · 01:53 UTC#64
What is in the root directory of the map installation SD? It should be:
Firmware (folder)
Update (folder)
CardInfo.CIF (if you are installing 2017 US/Can, the one from nezfotnemom's zip)
Edited Sep 02, 2017 by RonS
Posted Sep 02, 2017 · 02:04 UTC#65
Man thanks for the quick reply but I'm a dummy. I figured it out. I copied the whole file over to the SD so the HU was only seeing the folder with the files in it. So I took them out of the folder and it's updating now. I'll keep you posted on how it goes. This will be my first map update on the unit. Thanks again.
Posted Sep 02, 2017 · 02:30 UTC#66
Worked like a charm brother. Doing the nag screen next. Thanks a million!!
Posted Sep 02, 2017 · 04:12 UTC#67
Maybe I am missing something. I do not see a link to the actual maps file. It seems there are several individual files that are posted, but not the large map file. Is it just me? I recently updated to the 2015 update. I would love to update to the 2017 7.0 file.
Posted Sep 02, 2017 · 12:25 UTC#68
post 26 I think
Sorry guys had strep and hit me hard all week.. here you go:
https://drive.google.com/open?id=0B5KpUvEq0nCnb29SZFVlNTZrZUk
hopefully someone cracks it! Password: avic411s
Update: here's the zipped Cardinfo.cif needed for Z110/Z120/X920. Unzip and replace the one in the above archive.  I added this here since it's better to keep related files in one place. RonS
Posted Sep 02, 2017 · 18:17 UTC#69
well its not a giant map file.. its a zip, with a ton of files inside of it.. not sure what youre askin
Posted Sep 02, 2017 · 18:18 UTC#70
Sweet! Im going to try my own soon. Still dying  on the couch currently. Glad it worked
Posted Sep 03, 2017 · 05:15 UTC#71
Thanks. That was the file I was looking for. Somehow I missed it when I read the thread.
Posted Sep 05, 2017 · 14:35 UTC#72
Going to try this tonight! Finally not dying. On another note, anyone tried this with the x920/z120 cif file? I have a buddy with a z120bt who im trying to convince to try it but he doesnt wanna be the guinea pig  :mrgreen:
Posted Sep 05, 2017 · 17:38 UTC#73
Well on the F Series forum, they were successful installing the EU v7 on F20BT and F920BT. So the US should work with the correct CardInfo file.  I posted it earlier.  Make sure he follows the BT instructions in the installation manual - especially if it has old BT firmware ( < 3.10). If your bud has any issues connecting to iPod/Phone or other wired/wireless apps, do a hard reset and make sure App Connections is set correctly. I had to do that to get some things to work correctly.
Posted Sep 06, 2017 · 15:53 UTC#74
goos to go on my x940. Thanks your DLL did the trick. Still not sure what tf happend with mine.. i double checked it and everything was correct
Posted Sep 07, 2017 · 22:29 UTC#75
Hi! If I have an F940, can I install these maps instead of the EU ones?
Page 3 of 9
