I can't send 3gb thru my email. Gonna try upping to another free host.
2017 v7 US/Can Update available for Z110/120/130/140,X920/930/940
OK, here it is: http://www.mybyteideas.com/avic411/Pioneer_T1000-25818.zip
Somebody else put a password on it: avic411s
Blake, Smoke, Ron, netz, everyone...thanks! The instructions in this forum were simple and clear. This latest link worked like a champ. Did the install today, upgraded from factory original to v7.0 and BT v3.32. Still didn't fix my bluetooth connection which has never worked for android; now my phone tells me 'incorrect password' instead of just 'can not pair'. I'll keep working on that.
Recap: 8gb micro sd; FAT32 format; load and run shortfuse hack; get correct cardinfo file for x920bt; download link above; replace hack on sd card with cardinfo file, firmware folder, and update folder; run update [password = passwordpassword]; update firmware in bluetooth in settings; eject sd card; enjoy updated unit.
Just a note - Blake's link worked great. smokingman's link gave me a 23 hour estimated download.
Just completed the update tonight for the map and it worked flawlessly. However, when I updated the BT firmware, the unit no longer shows my iPhone connected in Bluetooth Audio mode but the phone is showing paired with the unit in the BT menu. Do revert the BT firmware version back to the pre 3.32 version or try something else?
7 hours ago, Kdogg said:...the unit no longer shows my iPhone connected in Bluetooth Audio mode but the phone is showing paired with the unit in the BT menu. Do revert the BT firmware version back to the pre 3.32 version or try something else?
You might try re-pairing the BT connection first. Sometimes it is necessary to do a hard restart after a bluetooth upgrade. Simple surefire way is to disconnect the battery for 30 seconds. Or, if you know both fuses that power the radio, you can just pull them.
If that doesn't fix it then try older BT firmware. maybe even re-installing 3.32.
6 hours ago, RonS said:You might try re-pairing the BT connection first. Sometimes it is necessary to do a hard restart after a bluetooth upgrade. Simple surefire way is to disconnect the battery for 30 seconds. Or, if you know both fuses that power the radio, you can just pull them.
I will try disconnecting the battery tonight. Thanks for the response!
upgraded 2x Nissan Xterras with Z130BT's to version 7.0000 and 3.32 bluetooth Yeah!!!(happy dance)......
followed instructions from
RonS,
crai6m4ck1
nezfotnemom
On 8/28/2019 at 11:26 AM, crai6m4ck1 said:
A quick recap for those coming here in the future to upgrade their head unit to version 7 firmware, 2017 maps, and the latest Bluetooth version. A special thanks to RonS for his help!
Quoted from an earlier post of his, “This is a hack to prepare your unit to install a map/firmware update. Confirmed to allow firmware updates for all Z110, Z120, Z130, Z140, X920, X930, X940 - and probably their corresponding rest-of-the-world units. I can't say whether it will work with the very old units, and it won't work with the model numbers ending in 50 or greater, or Nex units.
This should work with the following F series models:
F10BT, F20BT, F30BT, F40BT, F840BT, F8430BT, F920BT, F930BT, F940BT, F9210BT, F9220BT, F9310BT”
This is the process that worked successfully with my x930bt and I would assume should work with all the models listed above (though I make no guarantees).
First
Download the ShortFuseScript.zip from here:
Extract the files (Hacked.dll, ScriptExec.ini, and TESTMORE.KEY) and place them in the root of an SD card.
Insert the SD, it will prompt you to press any key (button) to continue - or - turn off the ignition to abort. Press a button and it should finish fairly quickly.
Next
Install the version 7 firmware and 2017 maps found here
https://drive.google.com/open?id=0B5KpUvEq0nCnb29SZFVlNTZrZUk
You’ll be prompted for a password to open the encrypted file
Password: avic411s
Extract the files out of the Pioneer folder and put them on the root of an SD card
Insert the SD card into the head unit and when prompted for the password enter: PASSWORDPASSWORD.
It should take up to 30 minutes to install
Lastly, go into Bluetooth settings and select upgrade firmware.
You’re done!
This is a really simple way to upgrade your unit that anyone should be able to handle. Just make sure that you keep the power on at all times. I even left my vehicle idling just to be safe.
For those not technically inclined, the Root of SD card means that the files are at the very top level and not within other folders. So when you open the SD card you immediately see the files and you don’t have to explore folders to find them.
Good luck!
Hello crai6m4ck1,
Thanks for this recap, when installing ShortFuseScript AND the firmware update, do we need 2 SD cards or will it work if we put all the files on one card?
20 hours ago, DBock said:Hello crai6m4ck1,
To be safe, don't put them on the same card at the same time. You don't need two SDs. You can install ShortFuse then format and re-use the same card for the map update.
5 hours ago, RonS said:To be safe, don't put them on the same card at the same time. You don't need two SDs. You can install ShortFuse then format and re-use the same card for the map update.
Great, thanks. I'll do that
OK guys, update worked well. Before I did the update (the reason I wanted to update in the first place) I could not connect my iPhone by Bluetooth since updating iOS to 15. After updating my Pioneer (including BT) it still won't connect. Anybody has the same problem since iOS update? Same thing with my wife's iPhone.
4 hours ago, DBock said:Same thing with my wife's iPhone.
Bluetooth issues have been known to happen after the BT update. Often they are fixed by disconnecting the car's battery for 30 seconds. In my case (Samsung Note - Android) I had to go to an older version of the BT firmware from the 2013 update.
First
Next
Password: avic411s
You’re done!
Good luck!
I know it's 2023 now, but having at least 2017 maps is still useful in the old beater Saturn I have my X930BT in, even though I use Google maps most of the time lol. Honestly the main reason for the update for me was the bluetooth update. As I was hoping it would, the bluetooth firmware update enabled media details (tracks, artist, etc) to display on the screen, as well as finally being able to use the back and skip button to control media playback. On the 3.22 firmware that was on my 930, the track info was just left blank and the skip buttons did nothing, which was quite infuriating... But with the 3.32 firmware, it works beautifully!
Following crai6m4ck1 steps worked perfectly without a single hitch.
I love that this forum is still active and keeping these older units alive!
Could someone repost the Pioneer_T1000-25818.zip file? Or, something newer for the X920BT? Thanks in advance!
Edit: Nm, found it here: http://www.mybyteideas.com/avic411/Pioneer_T1000-25818.zip
(not my link... amazing resources in this forum!)
I need some help. After i installed the shortfuse and it says i am ready to update the map. I remove the sd card and restart the unit. I inset the sd card with the map update, but nothing happens. Is it possible to use the supertest mode and force install the update?
2 hours ago, Pen3 said:I inset the sd card with the map update, but nothing happens. Is it possible to use the supertest mode and force install the update?
What model are you trying to update? It is likely you don't have the correct cardinfo file.
On 4/25/2024 at 9:49 PM, RonS said:What model are you trying to update? It is likely you don't have the correct cardinfo file.
AVIC-Z110BT. How do i go about getting the correct cardinfo?
1 hour ago, Pen3 said:AVIC-Z110BT. How do i go about getting the correct cardinfo?
Download the attached file and unzip. Then replace the Cardinfo.cif file on the update SD with the unzipped one.
39 minutes ago, RonS said:Download the attached file and unzip. Then replace the Cardinfo.cif file on the update SD with the unzipped one.
Thank you, it worked immediately.
