2017 v7 US/Can Update available for Z110/120/130/140,X920/930/940
By RonS · Jul 23, 2017in Hacks/Mods💬 220 posts👁️ 72,748 views
Page 8 of 9
Posted Dec 14, 2018 · 16:06 UTC#176
Not sure if it's been brought up, but it likely isn't the Brand of SD card, but the capacity.  Most of the older units discussed in this forum have a hard time with anything over the size of 16GB and they seem pretty picky about the formatting.  FAT16 or FAT32 only.
Posted Dec 21, 2018 · 06:28 UTC#177
Hello all, new to the forum. I stumbled along this thread when looking for UI mods instead I did the map update which is better than UI mods. I successfully updated my x930bt using the shortfuse and 2017 map dl.
As for the memory card I used a 2gig micro SD8gig off brand micro SDHC. I think the later models pioneer Navi will not except any micro SDXC. I could be wrong.
Thanks to everyone who contributed to making this possible.
Posted Dec 21, 2018 · 06:43 UTC#178
Edited Dec 22, 2018 by Tuanville — Reason: Got the answer already
Posted Jan 11, 2019 · 18:40 UTC#179
Hello everyone just did the update and all went well did the script on my Z110 then ran the map update now I am v7. only thing is that I have no gps and I am sure that comes from not having a factory gps antenna. I ordered one from amazon and it should be coming in Sat.. Oh I already upgraded my BT to v3.2 from yesterday when I loaded the 2013 maps. Just stumbled on this site.
P.S. the OP contribute link still works so I sent him a token wasn't much but I wanted to show him some love for sharing.
Posted Feb 17, 2019 · 19:40 UTC#180
On 8/8/2017 at 10:35 AM, RonS said:
Thought I'd post the Installation/operation manuals and info on the two 2017 updates (v7.0 firmware). I recommend that everyone review them before installing. Also note the specific instructions for upgrading BT from older( < 3.10) versions to v3.32. And as before, it doesn't seem possible to add iPhone Lightning connector support(patches 4.6 or 5.1) after the fact. It must be installed before installing firmware 6.0 and higher. IDK if there is a workaround.
Only Compatible With:
  • AVIC-Z110BT, AVIC-Z120BT, AVIC-X920BT         CDR5009A.pdf
  • AVIC-Z130BT, AVIC-X930BT, AVIC-X9310BT, AVIC-Z140BH, AVIC-X940BT    CRD5006A.pdf
As with other updates, either product can be made to install on any of the above units when used with the proper CARDINFO file.  See post #26 for the update files and see Shortfuse Hack for how to hack you unit prior to installing those files.
Sorry to revive an old thread, but the links to the manuals aren’t working.
Will this $120 update from navigation.com not just do maps but also firmware and BT? Will this latest BT update allow my iPhone X to work
I am trying to update my Z110bt which I have neglected for a few years
Posted Feb 17, 2019 · 23:52 UTC#181
The links I provided work. But those on Navigation.com are broken. Each release includes maps and firmware. I suggest you check the manual for specifics on support for iPhone and iTouch devices.
If you are still running on the original Z110 firmware (IIRC it was v 1.xxx), you might have serious issues installing the 2017 update version posted in this thread (for Z130 & Z140). Some people with original Z110 firmware had odd problems related to the tuner. I suspect it is caused by drivers for a different traffic tuner that is no longer supported.  I suggest that you install firmware specifically released for the Z110/Z120 to ensure you get the updated traffic tuner drivers (even if you don't use the new traffic tuner).
Edited Feb 17, 2019 by RonS
Posted Feb 18, 2019 · 01:30 UTC#182
Thanks Ron, your links now work. I think the site must have been having an issue.
I know I installed the paid update that pioneer had I think 2011 maps? Do you think I would be ok then since I have already made 1 update?
I don’t see anything in the manual about what iPhones would be supported now but I guess it’s worth a shot
Edited Feb 18, 2019 by Phillys finest — Reason: More stuff
Posted Feb 18, 2019 · 13:22 UTC#183
I think that will do it. I don't remember when they switched support for traffic tuners. I think it was in the first update after 2010.
Posted Mar 15, 2019 · 23:28 UTC#184
RonS  you are simply amazing!  I just read this thread and I am so impressed by your patience, gracious helpfulness and ability to understand, troubleshoot and diagnose problems—and your responsiveness is incredible!   Thank you so much!
I'm on a trip out of state (and I flew) and my car is at home, so I don't even have the option to try any of this out until I get back.  But this seemed like a good time familiarize myself with the process and the potential pitfalls...
I'm somewhat shocked by the number of people who do not carefully review the process making sure to actually understand all the steps and everything, especially on such costly "toys"!  I suppose I shouldn't be so surprised.
I've read at least half a dozen other threads on this site in the past and your presence, attitude & activity have been very stable and predictable.
Posted Apr 19, 2019 · 17:54 UTC#185
  1. Hey I did the update for everything and I seen for the bluetooth i brought it back down to 3.27 from the 3.32 and the bluetooth still is not working, what should I do?
Posted Aug 12, 2019 · 00:40 UTC#186
Thank you RonS and nezfotnemom. Updated my X930BT.. just need to get a GPS antenna in it and check out how well it works
Posted Aug 12, 2019 · 00:41 UTC#187
@James973 common suggestion is pulling the battery for a minute to let the unit reset
Posted Aug 20, 2019 · 17:23 UTC#188
On 8/25/2017 at 6:45 PM, RonS said:
Oh man, I feel for ya. Strep can knock the $hit out of you.  Rest up.
From the zip file name I see this is T1000-25818, which is for Z130/Z140/X930/X940. So older units will need a new Cardinfo. See the attachment.
Need a guinea pig to try installing on a Z110/Z120/X920. After unzipping, replace the existing CardInfo.CIF. No fears - if it is wrong, the update will not run.
For now, everyone will need to do the ShortFuse hack to get past the installation password. Hack
Z110Z120X920CARDINFO.zip
I just did this update with the Z110Z120X920CARDINFO file above on my AVIC-X920BT unit and it worked great. I upgraded straight from the original software to this 2017 version and then I ran the Bluetooth update. Thank you all so much! Now my Bluetooth will finally pair with my samsung S8 smartphone. I was about to purchase a new radio for $500 (including install) but not any more. Everything seems to be working fine including the backup camera. Thanks a million!
Posted Aug 27, 2019 · 02:24 UTC#189
Ok, so just to double check... I should use the ShortFuseScript.zip?  Unzip it to the root of an SD card, insert it into the unit and then "press any key (button) to continue" and let it do it's thing?  Am I missing anything?
Edited Aug 28, 2019 by RonS
Posted Aug 27, 2019 · 12:06 UTC#190
Correct.That fixes your headunit to bypass Pioneer's registration password validation. Then install the map update.
Posted Aug 27, 2019 · 13:36 UTC#191
And the map update is Pioneer_T1000-25818.zip ?
found here https://drive.google.com/open?id=0B5KpUvEq0nCnb29SZFVlNTZrZUk
Correct?
Posted Aug 27, 2019 · 14:04 UTC#192
Correct?
I don't know. I have nothing to do with posting  or hosting the file. Whatever it says in this thread.
Posted Aug 27, 2019 · 18:01 UTC#193
Ok, I'm all set.  I used the Pioneer_T1000-25818.zip to upgrade successfully to Firmware v.7 and Bluetooth V.3.32.
Does anyone know what specifically these updates changed/added?  I can't tell a difference in any user facing area.
Posted Aug 27, 2019 · 18:27 UTC#194
No change in the user interface.  Might be better BT support (but we've been on 3.32 since 2015) and new maps. Maybe some minor bug fixes under the covers. Who knows.
Posted Aug 28, 2019 · 15:26 UTC#195
A quick recap for those coming here in the future to upgrade their head unit to version 7 firmware, 2017 maps, and the latest Bluetooth version.  A special thanks to RonS for his help!
Quoted from an earlier post of his, “This is a hack to prepare your unit to install a map/firmware update. Confirmed to allow firmware updates for all Z110, Z120, Z130, Z140, X920, X930, X940 - and probably their corresponding rest-of-the-world units. I can't say whether it will work with the very old units, and it won't work with the model numbers ending in 50 or greater,  or Nex units.
This should work with the following F series models:
F10BT, F20BT, F30BT, F40BT, F840BT, F8430BT, F920BT, F930BT, F940BT, F9210BT, F9220BT, F9310BT”
This is the process that worked successfully with my x930bt and I would assume should work with all the models listed above (though I make no guarantees).
First
Download the ShortFuseScript.zip from here:
http://avic411.com/applications/core/interface/file/attachment.php?id=16863
Extract the files (Hacked.dll, ScriptExec.ini, and TESTMORE.KEY) and place them in the root of an SD card.
Insert the SD, it will prompt you to press any key (button) to continue - or - turn off the ignition to abort.  Press a button and it should finish fairly quickly.
Next
Install the version 7 firmware and 2017 maps found here
You’ll be prompted for a password to open the encrypted file
Password: avic411s
Extract the files out of the Pioneer folder and put them on the root of an SD card
Insert the SD card into the head unit and when prompted for the password enter: PASSWORDPASSWORD.
It should take up to 30 minutes to install
Lastly, go into Bluetooth settings and select upgrade firmware.
You’re done!
This is a really simple way to upgrade your unit that anyone should be able to handle.  Just make sure that you keep the power on at all times. I even left my vehicle idling just to be safe.
For those not technically inclined, the Root of SD card means that the files are at the very top level and not within other folders.  So when you open the SD card you immediately see the files and you don’t have to explore folders to find them.
Good luck!
Posted Sep 14, 2019 · 20:11 UTC#196
This is still usefull stuff to me.
Thanks all.
Posted Oct 30, 2019 · 18:49 UTC#198
Hi guys,
I have a bone stock X920BT, no map or firmware updates since I bought it.
I have downloaded and run the ShortFuse Hack, and downloaded the Z110Z120X920CARDINFO.zip.
Can anyone re-link the 2017 update? I'd be willing to donate for your time and effort. Like zoom says, the google drive link is empty.
If no one has the update anymore, does anyone have experience dealing with avicfix?
https://www.avicfix.com/2017-map-upgrade-pioneer-avic-x920bt-z110bt-z120bt/
Thanks all for putting out all this out there.
Posted Nov 03, 2019 · 00:23 UTC#199
I have the file but need a host. Whats a good free host as this file is 3gb?
Posted Nov 03, 2019 · 12:38 UTC#200
Send it to me, I'll host it. my forum name AT outlook dot com
Page 8 of 9
