2 hours ago, fshrlou said:Those are great Install pictures from those who posted. Very glad I found this forum. Learned quite a bit already.
Wanted to update you all on my bypass trials and errors. Found a company on eBay that was advertising in motion bypass for 2020 Pioneer NEX’s. It’s a triple pulse bypass. I had initially installed my WT7600 with a double pulse, which did work until I started moving. Ordered one thinking it would help with the speed pulse wire error. Received it, installed it, and once the 3D Calibration had initialized, I lost video. Went to Settings/System Information/3D Calibration and tapped on the Learning button. Chose Reset All, then video came back. At one point I had video for 13 minutes, then made a few turns, slowed down, then lost it until I came to a stop. If you have the VSS wire connected and reset everything, it will eventually initialize to 3D Hybrid and you will lose video. If the speed sense wire is not connected at all and you reset the learning, video will work briefly until the system initializes to a Simple Hybrid, the video is lost.
I drive with the kids a lot, so it’s more important to me than losing CarPlay functionality. Someone had posted that they pulled the GPS plug. Did video stay on consistently, or did it eventually go off?
Thanks for the help.
I had the GPS plug pulled on mine today and so far so good we'll see if that fixes the problem. Also the bypass on ebay that you ordered didn't work for you
