WT7600NEX & WT8600NEX First Impressions
By mapotter99 · May 30, 2020in NEX Series💬 144 posts👁️ 36,168 views
Page 3 of 6
Posted Jun 30, 2020 · 16:35 UTC#51
I dont think it has one. They replace that option with home screen layout
Posted Jul 03, 2020 · 13:39 UTC#52
Hi. After many hours of screen presses, I figured it out. The Pioneer DMH-W and DMH-WT models have a special hidden menu bypass requirement. No interface bypass is required, but you can leave it connected if it is already installed. Dean and Fernando at Five Star Audio made a video of it on the tubes if you’d rather see it than read it. Here is how to do it:
1. Update the firmware to 1.13
2. Enable the hidden menu bypass by sourcing the radio off (source off, not power off).
3. Press and hold the bottom left corner of the screen for exactly 10 seconds (use a stopwatch as timing is critical).
4. Within 1 second, press and hold the bottom right corner (to the immediate left of bluetooth icon) for 10-12 seconds until a small “set on” icon will appear (in the bottom middle of the screen) confirming the bypass has been activated.
5. If you do not get it the first time, cycle the ignition off and back on and start over.
6. If you need to reverse this process, reset the radio.
Posted Jul 04, 2020 · 18:09 UTC#53
Excuse my lack of knowledge, but what does opening up this hidden menu allow? Video while mobile?
Posted Jul 04, 2020 · 20:12 UTC#54
Everything that is normally locked out while the vehicle is moving.
I wouldn’t call it a “hidden menu”, exactly. More like a hidden override setting.
Edited Jul 04, 2020 by mapotter99
Posted Jul 05, 2020 · 17:01 UTC#55
I can confirm that all settings are now accessible while moving and video also plays, at least using the built in browser and YouTube. I don’t have an hdmi source set up to test but I would think that would work too. Works surprisingly well!
Only thing I found that doesn’t work is the keyboard in CarPlay, but Siri is easier to use anyways.
FullSizeRender.mov
Posted Jul 07, 2020 · 12:14 UTC#56
Will this also allow the backup camera to stay on? I would like to have it on while towing.
Posted Jul 07, 2020 · 12:19 UTC#57
you can have the camera as a widget
Posted Jul 07, 2020 · 21:07 UTC#58
I have it set that way, but once I reach 10+ miles and hour it turns off.
Posted Jul 07, 2020 · 21:48 UTC#59
what kind of car
Posted Jul 07, 2020 · 21:55 UTC#60
2014 RAM  1500
Posted Jul 08, 2020 · 17:32 UTC#61
On 6/28/2020 at 6:40 AM, mapotter99 said:
I’ll just go ahead and throw out that I’ve had zero problems with wireless CarPlay dropping out or range issues.
Do you happen to have "Hey Siri" turned on?
Posted Jul 08, 2020 · 23:44 UTC#62
Hey it’s Ivan from Reddit!
I’m out of town and can’t test it but I will when I get back on Friday. Although I do use hey Siri quite often with my AirPods, would suck to turn that off.
Your wireless CarPlay has been better still?
I was in a Cayenne today that had CarPlay built in and thought of you lol
Edited Jul 08, 2020 by Dizle — Reason: Added photo
Posted Jul 08, 2020 · 23:51 UTC#63
One more thing, I found some where on the inter webs that someone had success with wireless CarPlay interference by turning this off. I did it and it’s seemed to help but could be placebo.
The only thing that I can tell it turns off is direction airdrop, can no longer point your phone at another to send an airdrop. Didn’t work well for me anyways so I’m not missing much.
Posted Jul 09, 2020 · 03:15 UTC#64
Hey Markdizle.  Yup, its day 3 and no drops.  Although I dont want to keep it this way, I figure (if its truly proven) we could maybe email Pioneer to fix it?  I checked, I have networking & wireless on ... but might try it (and dropping LTE) if this doesn't work, but so far 3 days is pretty good.
Posted Jul 09, 2020 · 03:45 UTC#65
I called Pioneer about the crappy Siri quality and they immediately blamed my phone, I didn’t push it hard and just hung up. Got some low level tech on the phone just reading from a script.
I’ll give them a call this weekend and push the issue further as it’s not getting any better!
Posted Jul 09, 2020 · 15:44 UTC#66
I do.
Posted Jul 09, 2020 · 15:49 UTC#67
@IvanRaide I saw in your video on your thread about the volume knob mod that you are using the iOS 14 beta.
How is your Siri and phone call sound quality with the beta?
I’m still pinning this problem on Pioneer, as other cars don’t have this problem. I just hope it is fixable with software, and not due to them cheaping out on Bluetooth hardware.
Edited Jul 09, 2020 by mapotter99
Posted Jul 09, 2020 · 16:33 UTC#68
No, iOS14 didn't help that, Siri still sounds wrong, (like bluetooth mono).  I suspect it's not going to get fixed, they probably implemented phone and "voice dial" via HSP and HFP and not AVRCP/A2DP and I highly doubt they are going to go back and redo it, (I'm sure they are already onto new hardware and cant wait for you to buy that NEW hardware instead of this months old junk).  But, lets hope ....
I see you have "hey siri" on.  You have mentioned distance as well.  I have my phone always in my right pocket so about 2 feet diagonal to the center of the head unit, today is the 4th day of no drops for myself though.  One thing if you could try ..... say "HHHHHEEEEEEYYYYYYYY" (pretty loudly) and tell me if you get a few audio drops after that?
Posted Jul 09, 2020 · 16:38 UTC#69
I just spoke with Pioneer, and after checking, the support person I talked to said the metallic distant Siri is a KNOWN issue, and promised to forward my information to engineering!
So... call in AGAIN and really press the issue. Offer to help engineering fix this problem!
Posted Jul 09, 2020 · 16:40 UTC#70
I suspect you are right. That is typically Pioneer’s approach to these things after a few months on the market. Im hoping if enough of us complain this early on, they will have to fix the problem... IF it can be fixed with a software/firmware update.
I just tried Hey Siri while connected wirelessly. I had no drops. Everything worked properly.
Is anyone having the dropping problem on a WT7600NEX?  I’ve only heard of it on the 8600, so far.
Posted Jul 09, 2020 · 19:49 UTC#71
Yes mine drops on the WT7600NEX, although for no apparent reason it has gotten a little better. If I even wave my hand over my phone it drops, or heaven forbid I pickup my phone it drops too.
I’ll call them when I get home tonight and press the issue!
Posted Jul 09, 2020 · 22:04 UTC#72
So today is my 5th day with the HeySiri off (and today I drove to get lunch so technically I have driven 45-1hour 12 times) and on the 12th time (the drive home) it had 3 audio drops.  Now after crying uncontrollably,  I started to think “what changed”.  I just installed AdGuard Pro (which is a VPN adblocker) so it might be that, (and hence more evidence to “extreme wifi latency intolerance”).  This is more just FYI while we wait for a miracle....
Posted Jul 10, 2020 · 14:44 UTC#73
Yesterday I experienced constant severe audio cut outs even when my iPhone 8 Plus was in what I call the safe zone, 6 inches from where the 8600 is installed. Sometimes Apple Maps completely locked up on the screen coinciding with these audio cut outs. I’m hoping this is an issue that can be fixed via a firmware update, and isn’t a hardware shortcoming. I’ve owned wireless Kenwood CarPlay units prior to the 8600 using the same iPhone and never had this issue before. To me this rules out it being a iPhone/IOS/iPhone setting issue, but rather this issue points to it being directly related to the Pioneer head unit itself.
Question....Has anyone tested the audio cut out issue when running Android Auto wirelessly? I have a Samsung S9+ that I’m going to test with wireless Android Auto to see if it exhibits the audio cut out issue as we are experiencing with wireless CarPlay. This will help further narrow down whether this is a phenomenon in just the way Pioneer implemented their wireless protocol with wireless CarPlay, or if it’s more or less a hardware shortfall with the WiFi chip Pioneer chose to use in our units.
Posted Jul 10, 2020 · 15:39 UTC#74
Turned off hey Siri, no difference but worth a try
Posted Jul 10, 2020 · 16:41 UTC#75
Okay reporting back after testing my 8600 with wireless AA during a 30 minute drive. Well I’m happy to report that Android Auto runs flawless with a wireless connection. Not one single audio cut out when playing music and navigating via google maps/Waze. The wireless connection is solid and consistent with my Samsung Galaxy Flip being in my pocket during the entire drive. With my iPhone I couldn’t run CarPlay with it placed in my pocket without experiencing constant dropouts and the 8600 occasionally freezing during these dropouts. Not as severe, but this even happened when my iPhone was placed right near the head unit.
Since I’m not tied to a specific ecosystem and for the sake of enjoying my 8600 without issue for the time being, I think I’m going to roll with wireless Android Auto for a minute. Here’s hoping that Pioneer tighten up their WiFi protocol coding when using wireless CarPlay really soon.
Thanks.
Edited Jul 10, 2020 by Thorissr — Reason: Edit
Page 3 of 6
