I have a thread over at reddit (attached, comments have the meat) that covers my attempts to bring my w4500nex back to life after the internal SDCard toasted itself. Thus far I've installed an SD Extension cable so I can mess with the SDCard until my replacement arrives from Russia. Since then I've been able to get touchscreen working with the 4400 image posted on the development thread and have been deconstructing the updates to figure out if the sdcard password is somewhere in the updates (it's not on the SDCard but likley in the NOR flash that update does). Since messing around with the system I've locked about 5 of my SDcards (I picked up a bunch just incase).
So many dead-ends, but here's what I've been able to do so far
- Boot the 4400 image - this lead to the touchscreen not working
Modified the 4400 image to support the 4500, mostly works. here's what I did;
- used dd to write the image to sdcard
- copied build0.prop to build.prop and deleted all the other buildX.prop files - note, not sure if this or the next change is the one that ultimately took effect
- modified /etc/sysd.conf, updated the 8400nex config (sysdconf.com.TouchType) from "capacitator" to "resistence"
- Booted the w4500nex with the updated card
- Noticed that when the SDCard changes, the warp cache gets refreshed. This means I can change the files without the system changing them back. Either that or maybe WARP is only relevant after the cache gets built on the sdcard. Not sure.
Unfortunately while the radio mostly works (if not a bit buggy), I'm unable to login to the developer menu due to the password change from "DEVELOPDBG ON" - I'm digging through to see if I can find where they might have changed the password or bypass the password in general. I'm using binwalk to walk through the various files and updates to see what I can find. My hope is to be able to unlock my original SDcard, it appears to work but is locked which leads me to suspect that it's an issue with a corrupted file or bad block not affecting the whole SDCard. This will allow me to see the changes between it and the 4400 image I downloaded.
One interesting thing is that it looks like for the most part there's an overall image and each build just has config file changes. If that's the case, I'm really curious with the w8500nex 1.03 image as it might contained updated code while still holding driver support for the w4500. I'm also going to go down the path of looking how to create my own bsp files, I can't seem to figure out how to get this into testmode (the scripts don't seem to work anymore) to turn off the sdcard lock and unlock existing cards. If I can enable OpenSSH or adb over network (found the config files, need to learn more about adb) then I can mess with it while it's running. I hasn't haven't ran scans against it while wifi is running, that's how I gained access into my dashcam. I'm open to any suggestions, but if not with any hope this will help someone else trying to solve their w4500nex woes.
Please note: I'm not sharing proprietary code/i.e. sdcard images. I'll gladly answer questions and help guide but from the looks of it part of the reason other image files have been taken down are because of DMCA requests. Don't need that kind of noise.
