efeliciano13 Posted January 15, 2008 Report Share Posted January 15, 2008 my rear view camera was working fine when i went in reverse. however, now it doesnt work. i dont know why. i just installed fog lights onto my car but i didnt have to move any existing wires so i dont see how i could have messed it up. i know the camera work because when i go to v. adjust i can see the camera working. it just doesnt work in reverse. also, when installing the fog lights i was nowhere near the center console, thats where the gears are; not sure if that makes a difference. help please!!! Quote Link to post Share on other sites
Eggsack Posted January 15, 2008 Report Share Posted January 15, 2008 I was having trouble with mine too, but in a Z2. It turned out is was a loose connection where I taped into the reverse switch. So check all connections including behind the head unit. Then check fuses too. Quote Link to post Share on other sites
efeliciano13 Posted January 15, 2008 Author Report Share Posted January 15, 2008 do you know the colors of the wires for the rear camera because i had someone do it for me. Quote Link to post Share on other sites
Cowboy UP Posted January 17, 2008 Report Share Posted January 17, 2008 It might be the weather. I have been having trouble with mine. Mine is just black with the old tv line that move up. After my truck is warm and it warms up a little outside, it seams to work. I am using an audiovox licence plate frame camera. Got it at Best buy for 130 bucks. It works good, and it has a feature that always you to flip the image so it right. Pioneer did some stuff to the units that flip the image if you don't buy the pioneer camera. Let me know if it might just be the weather. I am just guessing about mine from experience. Work fine during the day, a little trouble when it gets dark. Quote Link to post Share on other sites
Cowboy UP Posted January 17, 2008 Report Share Posted January 17, 2008 yes you can tap into the tailight for your power and ground. The camera will only work and will get power when you back up though. Use the back up light hook up for power. you can ground by using the backup lights ground. It is the same idea as hooking up extra backup lights. I have done this and I have a backup camera for my truck. Quote Link to post Share on other sites
efeliciano13 Posted January 17, 2008 Author Report Share Posted January 17, 2008 mine is definately no the weather. it works, just not when i go in reverse like it used to. whats going on with this thing and how do i fix it? Quote Link to post Share on other sites
whtcrxghst Posted January 17, 2008 Report Share Posted January 17, 2008 Maybe the reverse wire came loose. Take it back to whoever put it in Quote Link to post Share on other sites
efeliciano13 Posted January 17, 2008 Author Report Share Posted January 17, 2008 how can i check it myself. it seems if you want it done right you have to do it yourself. so, how and where do i check. do i look behind the d3 or by the gears, or under the steering column? what color wire am i looking for? Quote Link to post Share on other sites
trol1374 Posted January 17, 2008 Report Share Posted January 17, 2008 I have a D3 and a Boyo camera. Now that the weather has gotten cold (in the 30's at times), the camera doesn't come on upon shifting into R after first starting the car for the day. Once it warms up in the car, then it works when shifting to R. The camera does work when I go to menu and rearview. Only does this when it is cold. Quote Link to post Share on other sites
