Ledetent Posted January 21, 2008 Report Share Posted January 21, 2008 Hello! I'm new to the forum and have a D3 on order. I've downloaded the manuals to get a head start on how to wire it up. Have a question... My plan is to try and wire up 2 front and 2 back speakers to D3 and use the internal amp. I have a sub that will have its own amp outside of the D3. Is it possible to wire it this way? Will fader work? I think if I had a separate amp for the 4 speakers I could use the RCA's and everything would work. Thanks for the help! Jimmy Louisiana Quote Link to post Share on other sites
whtcrxghst Posted January 21, 2008 Report Share Posted January 21, 2008 Yep, you will be fine Quote Link to post Share on other sites
Dane186 Posted January 21, 2008 Report Share Posted January 21, 2008 You can control balance and fade normally, sub woofer output is on a completely different menu. Quote Link to post Share on other sites
DJ Hellfire Posted January 23, 2008 Report Share Posted January 23, 2008 The sub is non-fading. Meaning if you fade to either the front or back interior speakers, the sub will still play. You will have to actually turn the subwoofer output off from the sub menu in order for it to not play while fading. Quote Link to post Share on other sites
