TonyH3 Posted January 30, 2008 Report Share Posted January 30, 2008 I love my D3. but it seems that there is about a 200 yard location issue. i thinks i am back about 200 er so yards. so when she tells you to turn i am by the turn. how do i fix this?? Quote Link to post Share on other sites
whtcrxghst Posted January 30, 2008 Report Share Posted January 30, 2008 Hook up your VSS wire and make sure the antenna is getting good reception Quote Link to post Share on other sites
TonyH3 Posted January 30, 2008 Author Report Share Posted January 30, 2008 Hook up your VSS wire and make sure the antenna is getting good reception done.. and good sig.. almost 100% Quote Link to post Share on other sites
HiFiSi Posted January 30, 2008 Report Share Posted January 30, 2008 Settings > Modify Current Location > Drag arrow to where you actually are. Drive a while and see if it fixes it. It helps to be on as straight a road as possible, or even a highway. Quote Link to post Share on other sites
apercele79 Posted July 27, 2011 Report Share Posted July 27, 2011 Settings > Modify Current Location > Drag arrow to where you actually are. Drive a while and see if it fixes it. It helps to be on as straight a road as possible, or even a highway. my current location is accurate but the arrow is upside down...it only drives sideways and upside down....im sooo anooyed with this D3 Quote Link to post Share on other sites
The Tos Posted August 16, 2011 Report Share Posted August 16, 2011 my current location is accurate but the arrow is upside down...it only drives sideways and upside down....im sooo anooyed with this D3 Was the D3 previously in another vehicle? If so, you need to go into the nav and reset the calibration to your specific vehicle. Let it relearn on your car. That seems to be fixing mine. Let us know if that works. Quote Link to post Share on other sites
ylwshakr Posted August 30, 2011 Report Share Posted August 30, 2011 Was the D3 previously in another vehicle? If so, you need to go into the nav and reset the calibration to your specific vehicle. Let it relearn on your car. That seems to be fixing mine. Let us know if that works. Didnt want to start a new thread but this is the exact problem I have been having. I had the unit in my car since new (2007) updated the maps and switched it to my SUV 2 weeks ago and having a time with it staying on track. I have done the modify location and it will work great for about 15 mintues and then it gradually starts to go sideways and backwards and all kinds of ways. Can anyone help me with that? Thanks. Quote Link to post Share on other sites
The Tos Posted August 31, 2011 Report Share Posted August 31, 2011 Didnt want to start a new thread but this is the exact problem I have been having. I had the unit in my car since new (2007) updated the maps and switched it to my SUV 2 weeks ago and having a time with it staying on track. I have done the modify location and it will work great for about 15 mintues and then it gradually starts to go sideways and backwards and all kinds of ways. Can anyone help me with that? Thanks. I had the same exact problem. You have to go into the calibration setting and reset all the fields. It has to re-learn for the new vehicle. This fixed the problem in my SUV. good luck. Let us know if it works. Quote Link to post Share on other sites
ylwshakr Posted August 31, 2011 Report Share Posted August 31, 2011 Yeah i did this last night. Its in the 3D settings. I cleared all 3 fields and then reset the unit. Seems to be working pretty good again so far. My only other question would be before i had some info on the speed pulse field. Now it stays at 0. Quote Link to post Share on other sites
The Tos Posted August 31, 2011 Report Share Posted August 31, 2011 Yeah i did this last night. Its in the 3D settings. I cleared all 3 fields and then reset the unit. Seems to be working pretty good again so far. My only other question would be before i had some info on the speed pulse field. Now it stays at 0. is your VSS wire hooked up? If not, than there wont be anything there. Quote Link to post Share on other sites
ylwshakr Posted August 31, 2011 Report Share Posted August 31, 2011 I would think yes because on that one screen it shows my speed and everything Quote Link to post Share on other sites
The Tos Posted September 1, 2011 Report Share Posted September 1, 2011 I do not have my VSS wire hooked up and still get the speed on the speedomoter feature. Quote Link to post Share on other sites
