cntrylvr79 Posted April 8, 2007 Report Share Posted April 8, 2007 [quote name="slarue4"]I did the bypass and everything seemed to work fine, the only thing is when the car reaches 5 mph, the bypass doesn't work anymore. Any suggestions?[/quote] Bypass isn't done right. Quote Link to post Share on other sites
coocho Posted April 8, 2007 Report Share Posted April 8, 2007 [quote name="cntrylvr79"] [quote name="slarue4"]I did the bypass and everything seemed to work fine, the only thing is when the car reaches 5 mph, the bypass doesn't work anymore. Any suggestions?[/quote] Bypass isn't done right.[/quote] yeah the bypass definitely isnt done right. If it was then the bypass would work at any speed. Quote Link to post Share on other sites
sportsfan21 Posted April 10, 2007 Report Share Posted April 10, 2007 Suggestions? Flip the switch. Ground the light green parking brake wire. Make sure thats done and the bypass will work. If it doesn't reset the unit and then try again. If it STILL doesn't then you're doing something wrong, plain and simple. Quote Link to post Share on other sites
hyoriu Posted May 15, 2007 Report Share Posted May 15, 2007 how do we ground the parking brake wire? Do we just connect that red cap to another wire thats grounded in the fusebox or something? Quote Link to post Share on other sites
mgtakahashi Posted May 16, 2007 Report Share Posted May 16, 2007 I have the same problem with mine N3. I have the green cable ground. I reset the unit. However, when I pass 10mph, I get the message that video cannot be display while driving (something like that). Any suggestions. Quote Link to post Share on other sites
cntrylvr79 Posted May 17, 2007 Report Share Posted May 17, 2007 [quote name="mgtakahashi"]I have the same problem with mine N3. I have the green cable ground. I reset the unit. However, when I pass 10mph, I get the message that video cannot be display while driving (something like that). Any suggestions.[/quote] Bypass isn't done right. Quote Link to post Share on other sites
