2006 Corvette POP from speakers
I Just had my Avic-D3 installed in my 06 coupe and been noticing a pop sound everytime i turn off the vehicle. Called my installer and he claims that its normal because of a module that he had to install to hear all of the factory tones over the car speakers. Anyone else have this problem?
I recall people having that problem in other cars with a factory amp. It required wiring in a resistor on the amp turn on lead from the head unit because it's voltage was too high for the factory amplifier. IIRC it was a 3K or 4K ohm resistor. You can get one at Radio Shack for a couple of bucks.
I didnt do the install my self , i had a stereo shop do it. I just wanted to find out the info so i can pass it on to my installer. Is there more than one module for my vehicle? If i added the resistor as mentioned above would that do the trick? Not sure if it matters but mine is also the non bose model.
