jfisher Posted August 13, 2006 Report Share Posted August 13, 2006 I have not been able to determine if the Z1 can be installed in a 2006 Toyota Corolla. When I checked at Tweeter they could not find an in-dash installation kit for the 2006 Corolla and told me the curve of the dash was the problem of using older kits. Has anybody installed in a 2006 Corolla? Thanks. Quote Link to post Share on other sites
ricerocket21x Posted August 13, 2006 Report Share Posted August 13, 2006 yes i have put headunits into 02-06 corollas. i have only seen a single din kit made by american international that is curvy. but i have not seen ne double kits for the new corollas if ur planning to put a z1 in. the size of the kit looks like u could fit a double din headunit in but it is held in by four 10mm bolts in the bottom and the entire dash wit the vents. i don't know if a kit would be able to support double dins since they r fairly heavy. Quote Link to post Share on other sites
Kurai Posted August 13, 2006 Report Share Posted August 13, 2006 I have a Z1 installed in my Corolla now 03 had to have the stock dash piece custom refitted with fiberglass but turned out ok xcept for small crack that is gonna get fixed next week from reinstalling the dash piece. Quote Link to post Share on other sites
jfisher Posted August 13, 2006 Author Report Share Posted August 13, 2006 I do not know anybody that can do a custom install here in Maryland and I am not sure how to find one that I can trust to do a good job. My son went to a local installer to have subwoofers installed and they did not do a very good job and they used standard off the shelf parts. The wire from the battery was too small and burnt up and the amp is always overheating so I am leary of small mom & pop shops. Your install looks good but I am not sure about the Z1 anyway now that I have found many of the nav features are turned off when the car is in motion. Thanks for your input. Quote Link to post Share on other sites
Kurai Posted August 14, 2006 Report Share Posted August 14, 2006 Thx glad to help yeah sux that you have to trust your pride and joy to joe bob don't give a f*** and they mess it up really erks me when that happens Quote Link to post Share on other sites
yamahatundrav8 Posted August 22, 2006 Report Share Posted August 22, 2006 it can be done hear's an install [img]http://www.tundrasolutions.com/photopost/data/500/AVN_install.jpg[/img] Quote Link to post Share on other sites
jfisher Posted August 23, 2006 Author Report Share Posted August 23, 2006 [quote name="yamahatundrav8"]it can be done hear's an install [img]http://www.tundrasolutions.com/photopost/data/500/AVN_install.jpg[/img][/quote] Do you know where the installer got the install kit that had the face frame with the correct curves or were they able to use the original face frame? Thanks Quote Link to post Share on other sites
drft84 Posted April 2, 2007 Report Share Posted April 2, 2007 METRA 95-8204 TOYOTA COROLLA 03 07 DOUBLE DIN RADIO KIT just did a install last week. hope this helps Quote Link to post Share on other sites
bobby121687 Posted June 22, 2007 Report Share Posted June 22, 2007 any1 know where you get the vss wire and revere wire for an 05 corolla? Quote Link to post Share on other sites
