GTI Chooch Posted June 5, 2008 Report Share Posted June 5, 2008 I am ordering the 900BT and I want to have Sirius. I know I am going to need to order the CD-SB10, and the SIRIUS SC-C1. My car (2008 VW GTI) currently has Sirius through the factory head unit. My question is, can I use the existing Sat Radio antenna? If so what additional items do I need to buy to get this to work? Or will the existing antenna plug into the SIRIUS SC-C1? Link to post Share on other sites
cjfduke Posted June 6, 2008 Report Share Posted June 6, 2008 I am ordering the 900BT and I want to have Sirius. I know I am going to need to order the CD-SB10, and the SIRIUS SC-C1. My car (2008 VW GTI) currently has Sirius through the factory head unit. My question is, can I use the existing Sat Radio antenna? If so what additional items do I need to buy to get this to work? Or will the existing antenna plug into the SIRIUS SC-C1? x2 ... i have an '08 VW GLI with Sirius and also would like to know what (if any) additional equipment i need if i already have a Sirius antenna/tuner installed. Link to post Share on other sites
whtcrxghst Posted June 6, 2008 Report Share Posted June 6, 2008 Take a picture of what the connector looks like on your factory antenna and report back Link to post Share on other sites
GTI Chooch Posted June 6, 2008 Author Report Share Posted June 6, 2008 Here's pic.... Keep in mind our factory antennas handle both terrestrial radio and Sat radio...not sure if this is going to screw anything up Link to post Share on other sites
stormeister Posted June 7, 2008 Report Share Posted June 7, 2008 My car (2008 VW GTI) currently has Sirius through the factory head unit. My question is, can I use the existing Sat Radio antenna? If so what additional items do I need to buy to get this to work? Or will the existing antenna plug into the SIRIUS SC-C1? I have a 2007 GTI and I was not able to use my Sirius antenna on my D3, I had to install a dedicated one... bummer. Daniel Link to post Share on other sites
Cyrus120Z Posted June 10, 2008 Report Share Posted June 10, 2008 my question is, i have the sat radio unit for the AVIC D3 will I be able to use that one or will i have to get another? Link to post Share on other sites
CamelTowing Posted June 10, 2008 Report Share Posted June 10, 2008 Same one will work with the Fs my question is, i have the sat radio unit for the AVIC D3 will I be able to use that one or will i have to get another? Link to post Share on other sites
ReconTrojan Posted June 15, 2008 Report Share Posted June 15, 2008 My car (2008 VW GTI) currently has Sirius through the factory head unit. My question is, can I use the existing Sat Radio antenna? If so what additional items do I need to buy to get this to work? Or will the existing antenna plug into the SIRIUS SC-C1? I have a 2007 GTI and I was not able to use my Sirius antenna on my D3, I had to install a dedicated one... bummer. Daniel Wow the misconceptions on this board are amazing. I have a 2008 R32, factory Nav. My installer used the factory Sirus antenna no problem! Works BETTER than the factory setup. Who is doing these for you guys? Link to post Share on other sites
Morfious Posted June 15, 2008 Report Share Posted June 15, 2008 I have the D3 and am considering the F series as an upgrade. My main concern is with Sirius. Do yo have to use the CD-SB10, and the SIRIUS SC-C1? Or can you use the SIR-PNR2 with the F series unit? I am mostly concerned with the Sirius display on the unit. I would be in haven if it has a 2 line display. Please post any observations in this regard. Thank you. Link to post Share on other sites
whtcrxghst Posted June 16, 2008 Report Share Posted June 16, 2008 You can use either of the setups you mentioned. They both have the same display functionality (one line) I have the D3 and am considering the F series as an upgrade. My main concern is with Sirius. Do yo have to use the CD-SB10, and the SIRIUS SC-C1? Or can you use the SIR-PNR2 with the F series unit? I am mostly concerned with the Sirius display on the unit. I would be in haven if it has a 2 line display. Please post any observations in this regard. Thank you. Link to post Share on other sites
