nick526 Posted July 15, 2008 Report Share Posted July 15, 2008 Ok, finally got around to installing my D3 along with some components and an amp. Had also planned to wire up the bluetooth and xm modules but the location I had planned for them wasn't to my liking after I saw the amount of cable I'd have to hide. So I've settled on another location, however I've already run the XM antenna to the original planned location and it won't reach the new spot. I really don't want to tear my interior apart again to re-rout the antenna wire. My question is this, is the wire for the antenna extendable? Is it just a simple copper wire that I can solder to an extension to give me the couple extra feet I need? I want to be carefull since I once got the idea to extend the headphones for my ipod only to find some wierd braided conductor inside the insolation instead of copper wire . Quote Link to post Share on other sites
Phlame217 Posted July 15, 2008 Report Share Posted July 15, 2008 No, I would not extend the cable, plain and simple. Quote Link to post Share on other sites
Julius Posted July 15, 2008 Report Share Posted July 15, 2008 No, I would not extend the cable, plain and simple. I second that! I've read where some were able to cut the wire and reattach with success and some weren't able to get a signal no matter how they reattached the wires.So I wouldn't cut it. Quote Link to post Share on other sites
nick526 Posted July 15, 2008 Author Report Share Posted July 15, 2008 ok. took your advice and re-routed it. might as well do it legit and not have any problems... Quote Link to post Share on other sites
HiFiSi Posted July 15, 2008 Report Share Posted July 15, 2008 Yeah, the antenna wire is coaxial, and the center conductor is TINY. You'd never get it spliced back together good enough to have it give you a strong signal... especially if it's been extended. Quote Link to post Share on other sites
