RMIN1 Posted July 22, 2008 Report Share Posted July 22, 2008 Does anyone know how to do this? I have been trying, but the phone keeps telling me that the bluetooth link is busy... Quote Link to post Share on other sites
bateyejoe Posted July 22, 2008 Report Share Posted July 22, 2008 Try this: 1. Break the current link between the phone and the unit (go into Bluetooth on the i580 and tell it to disconnect from the Pioneer). 2. Go into contacts, select a contact, pop up the menu and choose to send the contact. It should show the Pioneer as a possible destination. Select it. I had the same problem and this method worked for me on my DNX8120. I never got a chance to try it on my AVIC before returning it. Quote Link to post Share on other sites
RMIN1 Posted July 26, 2008 Author Report Share Posted July 26, 2008 that doesn't work. when you disconnect the bluetooth, it cannot interact with the radio anymore... Quote Link to post Share on other sites
HiFiSi Posted July 26, 2008 Report Share Posted July 26, 2008 I've got a Nextel i880... I'm having the same problem. It says the link is busy if I try to send it while connected. And when it's disconnected, it won't give you the option to send the contact via bluetooth. Quote Link to post Share on other sites
terron Posted July 26, 2008 Report Share Posted July 26, 2008 not sure how but I posted this in the wrong thread Quote Link to post Share on other sites
gjas18 Posted July 26, 2008 Report Share Posted July 26, 2008 Breaking the link works. 1. With the the phone connected hit transfer phone book 2. Go through all the menu boxes till the one that says hit ok when done transferring. Disconnect the bluetooth connection from your phone's interface and send business cards to the unit from your phone. 3. Profit! Worked fine with my phone which has the same issue of only one bluetooth connection at a time. Quote Link to post Share on other sites
HiFiSi Posted July 26, 2008 Report Share Posted July 26, 2008 Breaking the link works. 1. With the the phone connected hit transfer phone book 2. Go through all the menu boxes till the one that says hit ok when done transferring. Disconnect the bluetooth connection from your phone's interface and send business cards to the unit from your phone. 3. Profit! Worked fine with my phone which has the same issue of only one bluetooth connection at a time. It doesn't work... after starting the phonebook transfer process on the F90, I stop at that "hit ok when done transferring" prompt, then I break the bluetooth link through my phone, and when I go to transfer a contact via bluetooth, it can't find any device to send it to. Quote Link to post Share on other sites
gjas18 Posted July 27, 2008 Report Share Posted July 27, 2008 I had the same problem. How I solved it was going to the pairing screen on the Nav, telling it to pair from phone then canceling after my phone found the unit. My phone keeps the last search for bluetooth devices saved until another search is completed. So then I did the phonebook transfer and selected the Nav unit from the recently found devices menu. Most phones I've played with save the bluetooth devices found in the last search as long as you don't initiate another search. Try this and see if it works. This really should be fixed by Pioneer. The unit should go into discoverable mode when this box is reached. Quote Link to post Share on other sites
HiFiSi Posted July 27, 2008 Report Share Posted July 27, 2008 Cool... I'll give that a shot tomorrow and see what happens. Quote Link to post Share on other sites
RMIN1 Posted July 31, 2008 Author Report Share Posted July 31, 2008 anyone have any luck? Quote Link to post Share on other sites
HiFiSi Posted July 31, 2008 Report Share Posted July 31, 2008 Haven't had a chance to mess with it lately. Quote Link to post Share on other sites
wagon b0y Posted July 31, 2008 Report Share Posted July 31, 2008 i can't get my nextel i870 to send over the contacts either. It says link is busy. Quote Link to post Share on other sites
gjas18 Posted July 31, 2008 Report Share Posted July 31, 2008 i can't get my nextel i870 to send over the contacts either. It says link is busy. Read the above fix....... Quote Link to post Share on other sites
wagon b0y Posted July 31, 2008 Report Share Posted July 31, 2008 I'll give it a try. Quote Link to post Share on other sites
BmoreTrue Posted August 30, 2008 Report Share Posted August 30, 2008 hey yall this i my first post...im drew from baltimore and im a pioneer dealer.....i have the i580 and the F900BT and i had the same problem with the bluetooth link....so i broke the link and tried the transfer....it appeared that it worked but then when i reconnecte dmy phone it did not work soooo wtf....anybody called pioneer tech support on this? Quote Link to post Share on other sites
