cognizance8 Posted August 11, 2008 Report Share Posted August 11, 2008 I would really appreciate any help on this issue as my gps is pretty much unusable right now. I upgraded my Z2 to a Z3 and now my gps does not track correctly. The direction indicator that points in the direction of travel will drift and even change all the way so that it is pointing backwards. The position indicator also drifts and hangs up in places. I don't really understand why the computer can't figure out the direction of travel after taking samples and trying to learn, I am pretty sure that a garmin does this. Things I have tried to do to fix the issue : I have reset tall of the hardware several times (only momentarily fixes the problem) I have adjusted my position and direction manually on the screen (seems to fix it longer than resetting the calibration) Removed and re-installed the hard drive (no real effect) Things I might consider a problem : could it be a grounding issue? I never had this problem when it was still a Z2. Please help, any help is appreciated. Quote Link to post Share on other sites
garrettoomey Posted August 11, 2008 Report Share Posted August 11, 2008 One thought is to check the signal strength of the GPS antenae. How many satelites are you getting to lock? Could the antenea come loose or shifted positions? It sould like it is realying on the gyro and VSS... Quote Link to post Share on other sites
cognizance8 Posted August 14, 2008 Author Report Share Posted August 14, 2008 Thanks for the input. I checked that when it first started acting up. I am going to take it out of the dash this weekend and go through all of the wiring to make sure everything is on the up-and-up. It is indicating that the reception is fine. It is probably a wiring problem. Quote Link to post Share on other sites
GnatGoSplat Posted August 14, 2008 Report Share Posted August 14, 2008 How many miles have you driven it? It could be it just hasn't finished 3D Calibration yet. I think you can see this in Hardware under Settings, it will say something about Learning if still in learning mode. Quote Link to post Share on other sites
xplosion79 Posted October 3, 2008 Report Share Posted October 3, 2008 has anyone figured this out or have the same problem. Mine started after doing the z3 upgrade. I have the same problems with the indicator arrow drifting and sometimes being off track. If I reset the learning status it'll temporarily fix it. Seems like when this happens it'll say excessive vibration and the vss stops working. The head unit is mounted perfectly using the oem mounts on a lexus gs so I dont believe it can be from a bumpy ride. Quote Link to post Share on other sites
pritch0014 Posted January 5, 2009 Report Share Posted January 5, 2009 No need to go into detail. I'm having the exact same problems from a Z1 to Z3 upgrade. Quote Link to post Share on other sites
jsmart Posted January 12, 2009 Report Share Posted January 12, 2009 Had the same problem...went in and reset the 3D calibration settings...been a few days and so far so good! knock on wood... Quote Link to post Share on other sites
dagreat1 Posted January 26, 2009 Report Share Posted January 26, 2009 hmm i too seem to be haveing a similar problem Quote Link to post Share on other sites
