u2s1 Posted September 6, 2008 Report Share Posted September 6, 2008 The card is Fat32 and yes the drive works becuase I used it to play music. I have both folders in the root along with a folder for the sounds. Should I move the sounds somewhere else? Quote Link to post Share on other sites
Bman69 Posted September 6, 2008 Report Share Posted September 6, 2008 no you can have whatever else on the sd card and it wont matter when your loading testmode Quote Link to post Share on other sites
u2s1 Posted September 6, 2008 Report Share Posted September 6, 2008 I got it, must have been a bad card because I tried a new one and it works. Thanks for the help! Quote Link to post Share on other sites
cali007 Posted September 10, 2008 Report Share Posted September 10, 2008 I still cant get the copy window to close nor move. I've tried clicking the X repeatedly for like 10minutes and moving it via the blue upper bar. No luck. Any ideas? Quote Link to post Share on other sites
lemonhead Posted September 11, 2008 Report Share Posted September 11, 2008 I still cant get the copy window to close nor move. I've tried clicking the X repeatedly for like 10minutes and moving it via the blue upper bar. No luck. Any ideas? Â Calibrate your screen with the stylus, its probably not touching the right spot. Does the x look like pressing down when you touch it? If not you aren't calibrated enough. Quote Link to post Share on other sites
cali007 Posted September 11, 2008 Report Share Posted September 11, 2008 I did a quick search and couldnt find any threads about how to calibrate the screen would you mind giving me directions please? I really appreciate everyones help! Quote Link to post Share on other sites
BorisM Posted September 11, 2008 Report Share Posted September 11, 2008 It's in the manual. Or system settings... Quote Link to post Share on other sites
cali007 Posted September 11, 2008 Report Share Posted September 11, 2008 Worked like a charm! Sucessfully did my first hack and removed the blue boxes!Thanks so much to everyone on this board, its been a godsend. Quote Link to post Share on other sites
Join the conversation
