MiSZKiNKZ Posted August 25, 2008 Report Share Posted August 25, 2008 I just purchased the avic d3 about 3 weeks ago. It's in mint condition! Everything works great but I haven't really used the navigation so I decided to test it out by going to "my home" I made sure that my starting point was correct. About 4 miles down the road, it started showing that I wasn't even driving on the road? It was telling me to turn to streets that werent even there. Some of the streets it told me to turn to did not have the same name. When i finally got home, it said i was about 2 miles off from my actual location. When I tried to modify my location again, i actually found the right street except my house on the navi was supposedly on the beginning of the street when my house is really towards the end. Is it possible that I need the Navigation disk upgrade? Quote Link to post Share on other sites
HiFiSi Posted August 26, 2008 Report Share Posted August 26, 2008 1 - there is no upgrade disk yet. You can go to pioneer's website and go to the navigation section and click on the upgrades disk link. The disk is CURRENTLY due out in September, but the date keeps changing, so I wouldn't get too excited. 2 - Make sure your GPS antenna is getting a good signal, that the connector for the GPS antenna is firmly plugged into the unit, and that there is no metal over top of the antenna anywhere. 3 - Is the VSS/speed sensor wire connected? If not, hook that up because it can help with the GPS accuracy as well. Quote Link to post Share on other sites
MiSZKiNKZ Posted August 26, 2008 Author Report Share Posted August 26, 2008 1 - there is no upgrade disk yet. You can go to pioneer's website and go to the navigation section and click on the upgrades disk link. The disk is CURRENTLY due out in September, but the date keeps changing, so I wouldn't get too excited. 2 - Make sure your GPS antenna is getting a good signal, that the connector for the GPS antenna is firmly plugged into the unit, and that there is no metal over top of the antenna anywhere. 3 - Is the VSS/speed sensor wire connected? If not, hook that up because it can help with the GPS accuracy as well. oh i thought the one on the website was the upgrade... lol and my antenna is on top of my dash on the front left corner... and yes it is connected. so *shrugs* Quote Link to post Share on other sites
diemaster Posted August 26, 2008 Report Share Posted August 26, 2008 i had a simmler problem when i ,fortesting ,put the recever on the dash. i ended up taking out the headliner and instaling it inside the sunroof so it wont get stolen but has a clear view of the sky Quote Link to post Share on other sites
side4 Posted August 27, 2008 Report Share Posted August 27, 2008 if you bought this unit used you have to clear learned info from the other car it's under menu,settings,hardware info select distance and clear do the same for speed pulse and 3D calibration so the D3 will relearn all thise and your good to go. Quote Link to post Share on other sites
r6-rider07 Posted August 29, 2008 Report Share Posted August 29, 2008 i had a simmler problem when i ,fortesting ,put the recever on the dash. i ended up taking out the headliner and instaling it inside the sunroof so it wont get stolen but has a clear view of the sky Any way you can post up some pics??? Quote Link to post Share on other sites
diemaster Posted August 30, 2008 Report Share Posted August 30, 2008 yea let me go take em Quote Link to post Share on other sites
r6-rider07 Posted September 3, 2008 Report Share Posted September 3, 2008 haha..still waitin for you to get back from taken those pics. Quote Link to post Share on other sites
MiSZKiNKZ Posted September 4, 2008 Author Report Share Posted September 4, 2008 if you bought this unit used you have to clear learned info from the other carit's under menu,settings,hardware info select distance and clear do the same for speed pulse and 3D calibration so the D3 will relearn all thise and your good to go. uhm i already did that way before u even mentioned Quote Link to post Share on other sites
bdeitemeyer Posted September 17, 2008 Report Share Posted September 17, 2008 Pics? Quote Link to post Share on other sites
