kshockie Posted February 11, 2009 Report Share Posted February 11, 2009 Thanks Yazon, have you tried to conenct that yellow wire to the battery? I need to know whether the unit doesn't reboot afterwards. I've had it installed at Best Buy but maybe they messed it up. That's why I need to know if the yellow wire is the problem solver Quote Link to post Share on other sites
Yazon Posted February 12, 2009 Report Share Posted February 12, 2009 I haven't yet. I'm waiting for the ND-G500 amp to arrive and need to find how to mount this thing in my car. Quote Link to post Share on other sites
kshockie Posted February 12, 2009 Report Share Posted February 12, 2009 Thanks, dude. I too want to use it as a multimedia device but every time I start all the sound settings are reset and the thing always starts playing the first song! Quote Link to post Share on other sites
osafie Posted February 12, 2009 Report Share Posted February 12, 2009 If you connect the yellow cable, the unit does not turn off on crank. However, if you turn the ignition to the ON/ACC position, leave it there until the system turns on, and then crank the engine, the system will turn off and you will have to turn it on manually. I have had no problems with the unit turning on automatically after I crank the car. Sometimes it will reboot randomly at weird times, but it is very rare. Good luck Quote Link to post Share on other sites
