fiberglasslvr Posted September 5, 2008 Report Share Posted September 5, 2008 My AVIC D2 does not load the nav disk when i power it on it says loading pioneer navigation but then goes to please insert appropriate disk, so then i eject the disk and reinsert it and it does the same thing. i did reset it from the front but it did the same thing. please any help would be appreciated thanks in advance. Quote Link to post Share on other sites
HiFiSi Posted September 5, 2008 Report Share Posted September 5, 2008 Is it an original disk or a copy? Quote Link to post Share on other sites
fiberglasslvr Posted September 6, 2008 Author Report Share Posted September 6, 2008 it is an original Quote Link to post Share on other sites
GnatGoSplat Posted September 6, 2008 Report Share Posted September 6, 2008 Did this just happen suddenly, or did you buy it used and it was already like that? If the latter, my guess would be someone used a newer disc in it and you'll need to go through the downgrade procedure to use the original disc. I believe a search should find the downgrade procedure. Quote Link to post Share on other sites
jackyack18 Posted September 9, 2008 Report Share Posted September 9, 2008 the downgrade procedure can be found here: http://avic411.com/forum/viewtopic.php? ... =downgrade and some more help here: http://avic411.com/forum/viewtopic.php? ... t&start=15 if that doesn't work then you're in the same boat I am. Don't want to steal the thread but I think im going to have to send mine for repairs....f'n a Quote Link to post Share on other sites
