cognizantnamja Posted September 10, 2008 Report Share Posted September 10, 2008 So I installed the 700BT and hooked up the iPOD cable (RCA) in the process. Plugged into the USB cable as well. My sister says that the song titles and all that show up on screen but there's no sound. I made sure to tape the RCA cables together so that they don't fall out. I know the system is working as it plays the radio and CDs just fine. Any clues as to why it's doing this? Quote Link to post Share on other sites
NickyD32 Posted September 10, 2008 Report Share Posted September 10, 2008 a lotta times you just gotta pull the ipod out and start over. just disconnect it and plug it back in. this has happened to me before in my 900. did you switch AV1 to "iPod"? that's another common mistake Quote Link to post Share on other sites
lava10t2 Posted September 10, 2008 Report Share Posted September 10, 2008 From the Menu Screen, hit Settings, then AV Settings, then set AV Input 1 to Ipod Quote Link to post Share on other sites
HiFiSi Posted September 10, 2008 Report Share Posted September 10, 2008 From the Menu Screen, hit Settings, then AV Settings, then set AV Input 1 to Ipod DEFINITELY your problem. Quote Link to post Share on other sites
cognizantnamja Posted September 10, 2008 Author Report Share Posted September 10, 2008 Alright... I text'd my sis the instructions. Hopefully, this will solve the problem. Thanks, folks! Quote Link to post Share on other sites
cognizantnamja Posted September 12, 2008 Author Report Share Posted September 12, 2008 Update... indeed, your suggestions solved the problem. Gracias!! Quote Link to post Share on other sites
