bhud Posted September 15, 2008 Report Share Posted September 15, 2008 Hi all, AVIC d3BT We have one fitted to a Porsche Boxster. When the lights are switched on is there anything to be set so as the display darkens to night mode? Thank you inadvance for your help. bhud Quote Link to post Share on other sites
jaedee Posted September 15, 2008 Report Share Posted September 15, 2008 Yes, you don't have the illumination lead connected. (orange wire) Quote Link to post Share on other sites
HiFiSi Posted September 15, 2008 Report Share Posted September 15, 2008 Hi all,AVIC d3BT We have one fitted to a Porsche Boxster. When the lights are switched on is there anything to be set so as the display darkens to night mode? Thank you inadvance for your help. bhud Do you mean an AVIC-D3 or a European AVIC-HD3BT ? Because the HD3BT is not a "D-series" unit here in the US, it's a "Z series" unit. It's basically the European version of the AVIC-Z3 Quote Link to post Share on other sites
GnatGoSplat Posted September 15, 2008 Report Share Posted September 15, 2008 In Europe, they did have an AVIC-D3BT. I think it was an AVIC-D3 and CD-BTB200 bundle. http://caraudiosecurity.com/shop/produc ... /5821.html I agree on the illumination lead not connected. Although I believe there is also a setting in Settings to set whether night mode inverts the map or not. I'd check there first since it's easier than pulling the stereo out to check the wiring. Quote Link to post Share on other sites
jaedee Posted September 15, 2008 Report Share Posted September 15, 2008 I believe it is set to change by default. Quote Link to post Share on other sites
bhud Posted September 16, 2008 Author Report Share Posted September 16, 2008 Thanks folks will check the orange lead is connected Quote Link to post Share on other sites
brunp Posted September 19, 2008 Report Share Posted September 19, 2008 I have DRL's, so any info you pass along when illumination wire is likely not connected.... Paul Quote Link to post Share on other sites
