CatchMeIfYouCan631 Posted October 26, 2008 Report Share Posted October 26, 2008 There's usually a rubber grommet in the firewall where all the wires pass through into the cabin. I you find that and go through there, or you can drill a 1/2" hole out of sight and put a rubber grommet in there. Quote Link to post Share on other sites
axxman Posted October 28, 2008 Report Share Posted October 28, 2008 a trick I have used on an acura integra and now on my latest car is to run the amp power wire through the rubber boot for the hood release line. I run it from the inside out, it is a tight squeeze but you avoid drilling. I use just a little WD40 on the power cable to help it slide through. hopefully you are using an amp kit. also, for the remote turn on, you can still get rca cables that have an extra wire for the amp turn on, that is 1 less wire to run. I would take that wireing harness from the d3 and hook as much as you can together first. Try and bundle as much as possible together with zip ties to keep things from getting tangled. Good luck. Quote Link to post Share on other sites
Join the conversation
