WwRGSwW Posted November 16, 2008 Author Report Share Posted November 16, 2008 EVERY ONE PLEASE READ THIS ABOUT THE IMAGETBL.DAT! You do not need to worry about the 2nd or 3rd bits in for each line (The Character Count / Channel Number) We have discovered those bits are useless on our units... The way it reads the imagetbl is it looks at the text, and then references it to the 1st bit, which relates to the 4th, 5th, 6th characters in the PIM.. (DPSxxx) Cinemagic (was 27) Will still show up (Or should) the same logo on 76... Go out and try it right now! (With out any modifications), throw in your 2007 nav disk, and it should show up! Give me some time, And I will post a 100% Working IMAGETBL file.... Quote Link to post Share on other sites
cafagna Posted November 16, 2008 Report Share Posted November 16, 2008 Awesome! Seems like you are cracking the code! I remember seeing this kind of conversation back in January. Maybe this link may help you all. http://avic411.com/forum/viewtopic.php?p=82584#82584 Quote Link to post Share on other sites
axxman Posted November 17, 2008 Report Share Posted November 17, 2008 Hi wwwrbswww, I posted a excel doc earlier, I found the same thing, if the name has not changed at all it will work, my excel doc pretty much illustrates this. it makes sense because the titles are correct. so it does not get the title from the img.dat file. problem is, many channels stayed the same, but they are now called "sirius/xm". I read your discussion over in the f series forum. everything points to the img.dat file. hopefully you can get it working on an f series before you burn anymore discs. let me know if I can be of any help. Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 I have it working for the most part on the D series (Total of 7 DL DVD's) Quote Link to post Share on other sites
axxman Posted November 17, 2008 Report Share Posted November 17, 2008 I think the catagories changed as well, ex. latin is now Latin & World, I see them in the hex editor near the bottom. I guess this means it should be possible to add the new channels as well. Quote Link to post Share on other sites
tnova Posted November 17, 2008 Report Share Posted November 17, 2008 Looks like some hex editing and the new PIMs will solve things. I changed stations 4-9, 10, and 12. See picture, I took it 5 min ago. Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 Im sitting in my truck right now, whats weird is "The Heat" is an old chan... Its in the old file (diff chan #) but the icon is not showing up even with my hacked disc.... Odd!!!! Im going to burning disc # 8 tonight! I will give away all my test dics (working 2008 EAST nav discs) to people if they want to pay postage... They all have various stages of these icons, otherwise they work fine.. ) Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 Here is my current imagetbl.dat file... I am in the 60's (Near the heat) right now IMAGETBL.DAT Quote Link to post Share on other sites
tnova Posted November 17, 2008 Report Share Posted November 17, 2008 Are you working on the .PIM files or did someone already post them? Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 Someone made a bunch of PIM files... and PM'ed them to me, I have not tested them yet... Quote Link to post Share on other sites
tnova Posted November 17, 2008 Report Share Posted November 17, 2008 I just checked out your imagetbl.dat, looks like the heat is off by some- if you fix it you should be good. See pic. Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 No, check the original.. . the original was Left aligned... I tried that to see if right aligning it might work... that is something I did... but the original does not work Quote Link to post Share on other sites
axxman Posted November 17, 2008 Report Share Posted November 17, 2008 bmp files comming up. Quote Link to post Share on other sites
WwRGSwW Posted November 17, 2008 Author Report Share Posted November 17, 2008 AXX Please can you remove those icons from this thread.... The reason why I ask that, is because converting the JPGS to PIM wont work, they have to be BMP, and I dont want any one to get confused... If you convert them to BMP 32bit that would be amazing.. Quote Link to post Share on other sites
bggull Posted November 17, 2008 Report Share Posted November 17, 2008 I am working on all of the new PIM icons right now. I have sent a bunch to WwRGSwW. I have completed channels 2-48 as well as the channels that just switched numbers. WwRGSwW is going to let me know if the PIMs work. I will continue the editing process tonight. It will take me quite some time to finish the rest but hopefully we will have a working 2008 NAV disk with all the new XM logos in the end. Quote Link to post Share on other sites
