gloose Posted December 30, 2008 Report Share Posted December 30, 2008 I looked on crutchfield and it said the F90BT would not fit my 2002 GMC Yukon without Bose and with Onstar. I currently have an aftermarket stereo and was wondering if anyone has put the F90BT unit in a yukon or if it is possible to make the unit work even if its not suppose to fit. Quote Link to post Share on other sites
brianteel Posted December 30, 2008 Report Share Posted December 30, 2008 If your dash is a double din you are fine. you dont need bose to use this unit Quote Link to post Share on other sites
gloose Posted December 30, 2008 Author Report Share Posted December 30, 2008 I'm guessing its not double din because crutchfield said it would not fit my car. Quote Link to post Share on other sites
brianteel Posted December 30, 2008 Report Share Posted December 30, 2008 From the pictures i have seen it is 1.5 din Quote Link to post Share on other sites
gloose Posted December 30, 2008 Author Report Share Posted December 30, 2008 So it would be able to work? Quote Link to post Share on other sites
jrdiesel Posted December 31, 2008 Report Share Posted December 31, 2008 There have been others that have fit the deck into that truck. Search the forums for the 2002 Silverado install. Quote Link to post Share on other sites
madsonp Posted December 31, 2008 Report Share Posted December 31, 2008 My Expedition was also 1 1/2 DIN, however with a little creative dash modification I was able to fit a double DIN in it. Quote Link to post Share on other sites
chicken999 Posted December 31, 2008 Report Share Posted December 31, 2008 Hey, I have a 2003 silverado and they told me it would not fit, then they said I had to remove some brackets to make it fit, but mine went right in with no modifications at all, looks like it came from the factory to tell you the truth, couldn't be happier. I do think that 2003 was the year of a newer body style though, which could of had a different dash/radio setup than your 2002, but I doubt it would be that diferent. I would go for it. Quote Link to post Share on other sites
lseguy1 Posted December 31, 2008 Report Share Posted December 31, 2008 dont always trust crutchfield's info. It is NOT always accurate Quote Link to post Share on other sites
spider2k Posted December 31, 2008 Report Share Posted December 31, 2008 well in this case its right. D-Din in that truck isnt a direct fit. you will have to modify the sub dash to mount and the outer trim to fit. you can alternatively get the newer sub-dash and outer piece but it still needs some modification to work. Quote Link to post Share on other sites
gloose Posted December 31, 2008 Author Report Share Posted December 31, 2008 Thanks for all the help. I might end up taking it to a local stereo store and see what they can do when I purchase the unit. Quote Link to post Share on other sites
gloose Posted January 4, 2009 Author Report Share Posted January 4, 2009 I got an estimate for the install of the f90 and was $500 for a custom install because it does fit my dash. Does this sound right to anyone who has had a custom install? It sounds a little ridiculous but then again I have no idea. Quote Link to post Share on other sites
blackh8552 Posted January 5, 2009 Report Share Posted January 5, 2009 Seems like someone is trying to make a quick few bucks.. I only paid $429 for my f90 so $500 is a little crazy. Where do you live? If you are close to north jersey I have a shop for you. Quote Link to post Share on other sites
gloose Posted January 7, 2009 Author Report Share Posted January 7, 2009 No, I live in San Antonio, TX Quote Link to post Share on other sites
jrdiesel Posted January 7, 2009 Report Share Posted January 7, 2009 No, I live in San Antonio, TX ROAD TRIP!!!! And just think, you can use your Nav on the way back home. Quote Link to post Share on other sites
