zukgod1 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Well I had a huge reply all typed up but not complete, hit he "Save" button and I have no damn clue where it "Saved" it to. I'll send you a PM with my contact info and I can give you a quick walk through. Quote Link to post Share on other sites
zukgod1 Posted April 25, 2009 Author Report Share Posted April 25, 2009 Glad this post was of some use to someone. As far as a step by step goes there wasn't much to it. The screen has to be open. Turn the unit over so you can access the little panel where the ribbon is, remove the cover and slide the ribbon out. I can't remember at the moment which side was easier to remove. I think I removed it from the head unit then removed the screen. There are 2 screws holding the screen on the sliding chassis so once the screws are removed and the ribbon is removed you can twist the assembly out, be careful of that little spring that wraps around the screw on the right. Then just remove the screws from the housing you can use a small flat head to pry it apart. The insides are easy to disassemble once the case is taken apart. The touch screen just sits on the face of the LCD. the connection is removed then the touch panel can be replaced, reverse procedure for reassembly. Quote Link to post Share on other sites
Avalanche07 Posted July 8, 2013 Report Share Posted July 8, 2013 can u remember how to put back the spring?? I can't get it in place thanks Quote Link to post Share on other sites
biggmc1989 Posted August 3, 2013 Report Share Posted August 3, 2013 Turns out I broke the touch screen not the LCD. I was VERY easy to remove as well. I snapped a couple pics. Looks like they are listed upside down. Start from the bottom. And sorry they are so damn big. misc_092_307.jpg misc_091_838.jpg misc_090_410.jpg misc_089_419.jpg misc_088_827.jpg can u give me some pointers on taking this apart? Quote Link to post Share on other sites
garrettoomey Posted August 4, 2013 Report Share Posted August 4, 2013 This should help: http://avic411.com/index.php?/topic/21091-dis-assemby-photos-and-instructions/ Quote Link to post Share on other sites
GnatGoSplat Posted July 10, 2014 Report Share Posted July 10, 2014 Just curious if anyone has any detailed pics of the screen itself with the Pioneer board removed? I occasionally find these with cracked screens and replacements are prohibitively expensive through Pioneer. I wonder if these screens were manufactured by a different company (Sharp, AUO, LG, etc). Quote Link to post Share on other sites
Join the conversation
