brianmorris82 Posted March 3, 2009 Report Share Posted March 3, 2009 Does it Help? I searched the forums for a couple of hours and the only post i saw relating to this was this one ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: I have the SWI-PS and it works fine for me .... now. The "key beep delete" (search for it) mod made a HUGE difference in button responsiveness. Now the steering wheel controls respond much like OEM. A couple of notes after the mod, though: Holding down Vol Up or Vol Down buttons still sometimes makes the volume "run". But this only happens when I hold the button down for a long time (more than a couple of seconds). If I tap the button or just hold it down briefly, it responds right away and as expected (increment/decrement volume by 1 unit with a tap, by a few units with a brief button hold). Mute/unmute works fine (and yes, I do have the hardwire bypass with the mute wire moved), but it takes barely a tap. Hold it down for more than a tap and it doesn't work. Other than that, I'm a WHOLE lot happier with responsiveness after the "key beep delete" mod. EDIT: Here's a brief rundown on "key beep delete" (thanks to Stephanie and the ohter posters on this)... There are 8 files in the folder (DATA\Sound). The 40KB files to be deleted are: PSG1Hi PSG2Hi PSG1Low PSG2Low The other files (PSG3, PSG4, PSG5, VR) can be left alone. My experience: when I deleted these files, besides getting rid of the annoying key beeps, no adverse effects were noted and my steering wheel controls responded MUCH better (as noted previously by others)... :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: When reading the thread about "getting rid of the beeps" the op stated that she just replaced the .wav files with .wav silence files. The quote above suggest to just delete those files. Just wondering if anyone has any imput as to witch would work better. Also does anyone that has tried this had any luck? Vehicle is a 2005 toyota camry. Thanks in advance Quote Link to post Share on other sites
MegaMan X Posted March 3, 2009 Report Share Posted March 3, 2009 I think it helps ALOT I just deleted the files. I have a scion xB which uses the same wiring harness as your camry. Nothing bad has happend Quote Link to post Share on other sites
Auhdabey Posted March 4, 2009 Report Share Posted March 4, 2009 Where can these files be found to be deleted? I cant seem to find the "sound" folder inside the "data" folder I must be doing something wrong.... Im trying to do this on Maveric's Modified Data file. Thanks for the help! Quote Link to post Share on other sites
Bopper Posted March 4, 2009 Report Share Posted March 4, 2009 IMO the key beep delete is a must have. Quote Link to post Share on other sites
Sily_Rabit Posted March 4, 2009 Report Share Posted March 4, 2009 I used the test files to boot up the unit and then used explorer to get to the files. Once there, I just added an X to the end of each of the filenames. No more beeps. The normal beeps were bad, but after adding the pac, they were insane. All good now. Quote Link to post Share on other sites
Auhdabey Posted March 5, 2009 Report Share Posted March 5, 2009 So once I boot into TestMode... Where do I go to navigate to the audio files for the key beeps? Quote Link to post Share on other sites
brianmorris82 Posted March 6, 2009 Author Report Share Posted March 6, 2009 I just made a new folder and dropped those four files into it. Steering wheel controls are much better now. would recommend to anyone Quote Link to post Share on other sites
Paladin Posted March 6, 2009 Report Share Posted March 6, 2009 Oh man this is the ticket. Thanks guys! It responds almost OEM now. I was starting to hate that delay between presses. I just renamed my files to "-old" at the end. Works great. Quote Link to post Share on other sites
sperkins Posted March 6, 2009 Report Share Posted March 6, 2009 Thanks so much. This is great. But does anyone still get a beep when they press the menu button to get to the Top Menu? All my beeps are gone except for this one. Quote Link to post Share on other sites
Bopper Posted March 7, 2009 Report Share Posted March 7, 2009 Yes, still get that one. Quote Link to post Share on other sites
kwistofoo Posted March 9, 2009 Report Share Posted March 9, 2009 afaik, nobody has found the file that contains the top menu beep. Quote Link to post Share on other sites
snake212 Posted November 3, 2009 Report Share Posted November 3, 2009 sorry to bring up a old post but i figured it would be better than opening a new thread. i just installed the f700bt in my 2008 Camry SE and i have the basic steering wheel controls volume up/down skip up/down and the mode button. i just wanted to ask what did you guys program the mode button to do since all Toyota's are pretty much the same. i wanted to program it to act like i pressed the volume knob to get voice activation or when i hold it to mute. is that possible? feedback would be highly appreciated. Quote Link to post Share on other sites
m5james Posted January 31, 2010 Report Share Posted January 31, 2010 Can someone post a link on this thread for a newbie (under a week of ownership) about how to get into the screens, etc to remove the key beeps? I had the contant beeps from any button being presses, so I'd love so assistance on how to delete them all. - EDIT: found it after searching for "remove key beep" and followed a thread w/ a nice step by step writeup. I was just on a PAC thread about how the volume does fine on single presses, but does the run thing when I hold if for too long. The reaction on my F90BT in general is way slower than I expected it to be, so anything I can do to make it react quicker would be great. Since this is a Windows based deck, can we run a CPU clocker or something to make it react to button touches, boot up screen, between modes, etc go faster? Quote Link to post Share on other sites
