crispins Posted March 11, 2009 Report Share Posted March 11, 2009 I have an Aug 07 Z2 After much hesitation I finally upgraded the Firmware and moved a wire to ground in the harness closest to the ANT and ----- BAM ---- It works. Now I have to still clear the warning message and the parking Brake wire is wrong message but after that it plays. Now is there a way to get rid of those 2 messages? Thanks everyone!! Quote Link to post Share on other sites
CaptainInsaneO Posted March 11, 2009 Report Share Posted March 11, 2009 To get rid of the parking brake message, you need to ground the light-green wire as well (this is also beneficial in that in a few days, the system is going to lock you out again if you don't do it). We haven't figured out a way to get rid of the warning message yet. Quote Link to post Share on other sites
crispins Posted March 12, 2009 Author Report Share Posted March 12, 2009 I hve already grounded out the parking brake wire as well. I have done the 2 wire mod and the Z2 Firmware upgrade. I was wondering if I could get rid of the 2 warning/error messages with any programming. SOunds like I cannot and just have to clear out both messages everytime. Quote Link to post Share on other sites
garrettoomey Posted March 12, 2009 Report Share Posted March 12, 2009 If you bypass is done correctly, you will not get the parking brake message. You should only be getting the single warning about video while driving blah blah blah. Quote Link to post Share on other sites
crispins Posted March 12, 2009 Author Report Share Posted March 12, 2009 If you bypass is done correctly, you will not get the parking brake message. You should only be getting the single warning about video while driving blah blah blah. Well I have the light green parking brake wire grounded. The error I get says "....Detected that your parking brake is installed improperty..." How do I get rid of that message? Quote Link to post Share on other sites
CaptainInsaneO Posted March 12, 2009 Report Share Posted March 12, 2009 Check the actual "seat" of the wires at the connector on the back of your HU. Sometimes those come loose (has happened to me once). Quote Link to post Share on other sites
