woody17 Posted May 8, 2009 Report Share Posted May 8, 2009 Hi guys, Tried searching but I can't find. I need to reinstall the stock 2.0 pioneer settings because i'm having some malfunctions with the unit and am going to return it as a defective unit. anyhow, how do i load up the stock 2.0 settings? i did make a backup copy of "My Flash Drive," so if I should use this I have it. also...pretend you're talking to a 12 year old when you try to explain this to me. I actually am very smart, however I seem to never be good at these types of things. THanks! Wood Quote Link to post Share on other sites
jmuenni Posted May 9, 2009 Report Share Posted May 9, 2009 I had a similar situation. All I did was double tap on the "My Flash Drive" folder on the SD card that held my back up files. (This is after I booted the unit up in test mode) Then I clicked on EDIT/SELECT ALL, then COPY Then navigate to the "My Flash Drive" on the head unit, double tap on "My Flash Drive" then select EDIT/PASTE. It will copy the entire contents of My Flash Drive over the top of your moded files, restoring them to the original factory files. Assuming your backup is of the original before-mod factory unit... The transfer takes a good 20 minutes or so, so DO NOT turn the ignition off while transferring! Hope this helps. Good Luck! Quote Link to post Share on other sites
woody17 Posted May 10, 2009 Author Report Share Posted May 10, 2009 ok...it says something about only being able to copy as many files as there are space for...do i have to delete the current flash drive, then move the one from the SD card back onto the explorer? or do i just do as written, click my flash drive, click paste, then click ok to the warning "limited space" warning? thanks! joe Quote Link to post Share on other sites
crilleym Posted May 10, 2009 Report Share Posted May 10, 2009 ok...it says something about only being able to copy as many files as there are space for...do i have to delete the current flash drive, then move the one from the SD card back onto the explorer? or do i just do as written, click my flash drive, click paste, then click ok to the warning "limited space" warning? thanks! joe Just do it anyway and don't delete the current flash drive. I had to do that to mine 3 times while changing back and forth from different mods and it always worked for me. Quote Link to post Share on other sites
jppong1818 Posted June 4, 2009 Report Share Posted June 4, 2009 Anyone have original file to restore my f500bt back to stock setting? I did not backup before putting in hacks. Thanks Quote Link to post Share on other sites
crilleym Posted June 4, 2009 Report Share Posted June 4, 2009 Anyone have original file to restore my f500bt back to stock setting? I did not backup before putting in hacks. Thanks If you came to this forum looking to hack your unit and read how to do it, why would you not back up your unit? It is posted on everyone's mods.."back up before modding". Find cmh's reset to oem zip. Good luck. Quote Link to post Share on other sites
nowayjose Posted June 9, 2009 Report Share Posted June 9, 2009 My oem backup is corrupted for some reason. Anyone know where to get the orginal oem backup? and How to restore to orginal? I have a F500-BT. Thank you, Quote Link to post Share on other sites
