ralmeida Posted June 15, 2009 Report Share Posted June 15, 2009 Hi folks, I have updated to 2.7 (unfortunately) I have tried to downgrade to previous version but i can't beucase the unit ignore everything. If i use a sd card with no matter what the unit jump to the last audio source. I have try the same sd card with the 2.7 upgrade and the result is the same ... it seems that the unit knows that the installed firmware is the 2.7 so it jumps because the sd card have the same or older fw ... sorry for the english ... i am not a native writer. Quote Link to post Share on other sites
stappel Posted June 16, 2009 Report Share Posted June 16, 2009 I decided to dissect the new .zip file. It only contains a few new files: WINCEIMG.BIN v6.1.7.0 -> v6.1.7.2 (The Windows CE ROM) ezrider.exe v8.0.0.61795 -> v8.0.0.86638 (iGo v8.0) Lang_Polish.zip (Polish language files) SystemSetting.exe and Update.exe (no version info change), but those are compiled against the CE ROM and might be the reason why testmode does not work anymore. I'll try to update the ezrider.exe later today via the testmode if it has any visible changes, which i don't expect due to the fact the release notes only say something about TMC. Quote Link to post Share on other sites
demetrios77 Posted June 16, 2009 Report Share Posted June 16, 2009 Let us know what you find out, because I really need to get back into testmode to install my Cyprus maps, which pioneer does not include. -D Quote Link to post Share on other sites
OBenned Posted June 17, 2009 Report Share Posted June 17, 2009 I decided to dissect the new .zip file. It only contains a few new files: WINCEIMG.BIN v6.1.7.0 -> v6.1.7.2 (The Windows CE ROM) ezrider.exe v8.0.0.61795 -> v8.0.0.86638 (iGo v8.0) Lang_Polish.zip (Polish language files) SystemSetting.exe and Update.exe (no version info change), but those are compiled against the CE ROM and might be the reason why testmode does not work anymore. I'll try to update the ezrider.exe later today via the testmode if it has any visible changes, which i don't expect due to the fact the release notes only say something about TMC. I would also like to know if it possible to downgrade Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 OK guys, here it is. Download this http://rapidshare.com/files/246346538/winceimg.rar Unzip to empty SD card. Put card in slot. Press "MENU" "MAP" "EJECT" & reset button (left to "EJECT") , Keep them all pressed. Release reset button, wait for beep, release "EJECT" button and the others. You should get a blue screen. Now DO NOT press reset button as they ask. There is combination of buttons to enter service mode. Each time you press the button or control knob(up, down, left, right) small red square appears at the bottom. Here is sequence: up, up, down, "MENU", left, right. Then you have menu. Choose "0-upgrade wince" by pressing control knob. Next menu, choose (by means of control knob) upgrade from SD card. Wait & when everything is finished remove card & reset unit. This is not my invention, I just collected information from this forum. Thanks should go to man: xJ2Mx. Enjoy unlocked unit Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 OF course everything you do is for your responsibility. Playing with this can brick your unit. Quote Link to post Share on other sites
BrianF Posted June 19, 2009 Author Report Share Posted June 19, 2009 Thanks Konick, great information Quote Link to post Share on other sites
ralmeida Posted June 19, 2009 Report Share Posted June 19, 2009 Thanks Konick, you are the man. Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 thx, i hope after weekend, everybody who made update 2.007 will be happy again & PIONEER will not get me to court Quote Link to post Share on other sites
krasspc Posted June 19, 2009 Report Share Posted June 19, 2009 So by applying this CE upgrade I will do a restore to the older 2.005 firmware or will this modify the 2.007 fw to testmode working again? thanks Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 Apl version 2.007 stays, but with this procedure you can do whatever you want with your avic flash. Quote Link to post Share on other sites
krasspc Posted June 19, 2009 Report Share Posted June 19, 2009 Apl version 2.007 stays, but with this procedure you can do whatever you want with your avic flash. Great! Thx. I have applied the EZrider hack to get it working with latest german map. I guess this won´t work after updating to 2.007. Quote Link to post Share on other sites
konick Posted June 19, 2009 Report Share Posted June 19, 2009 OK once more. After downgrading you can use testmode again and do what you could do before updating to 2.007 Quote Link to post Share on other sites
krasspc Posted June 19, 2009 Report Share Posted June 19, 2009 OK once more.After downgrading you can use testmode again and do what you could do before updating to 2.007 I got it. Thank you. Very nice work Quote Link to post Share on other sites
BorisM Posted June 19, 2009 Report Share Posted June 19, 2009 Since the 3.0 upgrade must work with both 2.007 and older versions, there has to be some variation of test mode that works on both. Once the 3.0 is available it should be possible to determine how it works... Quote Link to post Share on other sites
