shanec Posted July 3, 2009 Report Share Posted July 3, 2009 Just got a AVIC-700BT. The box says updated for 2.0. The install manual shows a pink wire for the vss speed sensor connection - BUT....there is no pink wire. The power connector harness that came with it (the one with batt, acc, illum, speakers) has no pink wire. There's an empty pin in that harness, so I assume that's where it used to go. The box also came with no long pink wire to run from the harness to wherever I was gonna get a VSS pin. What's up with this? Quote Link to post Share on other sites
BorisM Posted July 3, 2009 Report Share Posted July 3, 2009 Just got a AVIC-700BT. The box says updated for 2.0. The install manual shows a pink wire for the vss speed sensor connection - BUT....there is no pink wire. The power connector harness that came with it (the one with batt, acc, illum, speakers) has no pink wire. There's an empty pin in that harness, so I assume that's where it used to go. The box also came with no long pink wire to run from the harness to wherever I was gonna get a VSS pin. What's up with this? 700 being a lower-end model does not have gyro or VSS input. Quote Link to post Share on other sites
bloodninja Posted July 4, 2009 Report Share Posted July 4, 2009 Just got a AVIC-700BT. The box says updated for 2.0. The install manual shows a pink wire for the vss speed sensor connection - BUT....there is no pink wire. The power connector harness that came with it (the one with batt, acc, illum, speakers) has no pink wire. There's an empty pin in that harness, so I assume that's where it used to go. The box also came with no long pink wire to run from the harness to wherever I was gonna get a VSS pin. What's up with this? Doesn't the manual also say that the VSS is "unnecessary" for the 700 on the same page? Quote Link to post Share on other sites
shanec Posted July 4, 2009 Author Report Share Posted July 4, 2009 Doesn't the manual also say that the VSS is "unnecessary" for the 700 on the same page? LOL, sure does. "unneccessary" is a bit of an understatement. Not only isn't it neccessary, its impossible! Quote Link to post Share on other sites
