Jump to content
AVIC411.com
Watching Videon on AVIC-X910BT
Yes it is still necessary to ground the parking brake wire to have the bypass work with the software bypass.
Disagree, I have the F910BT (EW version of the X910BT) and I only editted the pioneer.ini file , no wire changes at all, and now I have full nav features and video playback whilst in motion.
well that just means that your p brake wire is already grounded
Link to post
Share on other sites
Were it true that my parking brake was 'already grounded' then how would you explain that prior to the softmod , when I lowered the brake the video stops and when I raised it it resumed ? I did the AVIC install myself and can assure you all that the parking brake wire is connected correctly (to the switched side , not the ground side) of the parking brake.
Link to post
I'll add my two cents for the record.
I had a new X910BT (version 3.0101) installed and decided to bypass it.
First I tried just the software mod and that didn't work. Then I grounded the green wire to the parking brake switch and that worked. So in my case I had to.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
