bsnively Posted August 27, 2009 Report Share Posted August 27, 2009 Nothing on there indicates that it shouldn't. Does the on/off work for you on the other data.zip posted (the lastest one) on the how to topic? That one should be setup to hide the big list and show a small icon. (Btw - decided to redo it slightly for myself. here is a screenshot (now just showing four ones that I cared about towards the right side) Thx, Ben Edit: let me know and I can post the latest one that works for me...but the older ones on the HOW-TO forum should work too... Quote Link to post Share on other sites
bryvale Posted August 27, 2009 Author Report Share Posted August 27, 2009 I didn't use the DATA.zip on the "how to", I just added the code form the directions and a little extra help. I did add the button you mentined at one point but it didn't do anything. I do like how your map is set up but I don't have the icons on the top left....I'm using the quick start icons from Keeper's mod. Would it be defficult to remove those icons and add the quick start menu? Quote Link to post Share on other sites
bryvale Posted August 29, 2009 Author Report Share Posted August 29, 2009 Ben, Can you post your DATA.zip. I'll try using it as a starting point. Also, what is the code for the icons on the top left? I will probably remove those to add the quick launch. Thanks, Bryan Quote Link to post Share on other sites
Join the conversation
