vitaminb6 Posted February 2, 2010 Report Share Posted February 2, 2010 I'm having the strangest problem with VR, which I described to Pioneer support in email (see below). They asked me to phone instead which I will do, but wondered if anyone here had any ideas... I'm having a very specific problem with the voice recognition in my Z110BT. It is installed in my 2005 Audi A4, where it replaced the previously installed F90BT. The problem is that it virtually never understands when I use the CALL command. The strange thing is, it easily understands all the other commands I've tried, including complex sequences such as when doing FIND ADDRESS. I've explored the microphone as the potential cause, and have tried the following: - using the already installed microphone from the F90BT - replacing the microphone with the one that came with the Z110BT installed in the same location - trying an alternate location for the microphone The behavior has remained identical despite the microphone changes - all commands work well except for CALL which almost never works. Is this a known issue? Please advise. Quote Link to post Share on other sites
VBLUE42 Posted February 2, 2010 Report Share Posted February 2, 2010 Do you hit the OK button on the map screen before the BT connects? Quote Link to post Share on other sites
vitaminb6 Posted February 2, 2010 Report Share Posted February 2, 2010 I would have to say that yes, I often hit the OK button before the BT connection is established. Is this somehow causing the problem? Quote Link to post Share on other sites
VBLUE42 Posted February 2, 2010 Report Share Posted February 2, 2010 If the BT connects before you hit the OK button, BT calling will fail. It appears to be a bug with the system and has been reported to Pioneer. Do some testing on this to be sure and see if the problem goes away for you. Quote Link to post Share on other sites
vitaminb6 Posted February 2, 2010 Report Share Posted February 2, 2010 Thanks!! I will definitely give this a try. Quote Link to post Share on other sites
vitaminb6 Posted February 3, 2010 Report Share Posted February 3, 2010 Confirmed by testing - this was the problem. I'll ask Pioneer if/when a fix will be available. Thanks for your help! Quote Link to post Share on other sites
vitaminb6 Posted February 9, 2010 Report Share Posted February 9, 2010 I asked Pioneer about a fix, using the email discussion I already had on the go with them on this issue. Unfortunately no response whatsoever... Quote Link to post Share on other sites
tombonneau Posted February 20, 2010 Report Share Posted February 20, 2010 I am having this *exact* same problem. Hopefully this is the solution. God bless the search function. Quote Link to post Share on other sites
