Jump to content
AVIC411.com
Bypassing F9110bt gone wrong!
but what is the shit whit the mute wire then ?
From the ISO 10487 Car radio connector standard :
Pin 2 - mute control - grounded by external components to mute the radio, often used when a mobile telephone is fitted to the car.
but you say if the pioneer works again i should just ground the PB wire nothing more nothing less?
Once you disconnected the mute from ground, the radio shoulkd play normal volume again and when you ground the PB wire (or pull the parking brake) you should be able to enter the the pass...
Also make sure you didn't blow a fuse (either in the car or the avic)
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
