matty dread Posted June 17, 2010 Report Share Posted June 17, 2010 I want to use my droid to play music through my z110bt. Blue tooth does not work that great. Will it work if I use the usb cable and unplug the ipod interface? or should I get a standard 3.5 cable and run it in that way? Any setting to make any of this work? I hooked up a 3.5 and plugged in and got no sound from my droid but no sound from stereo either. Do i need to set it to aux or something? Quote Link to post Share on other sites
johnforeman Posted June 21, 2010 Report Share Posted June 21, 2010 i run mine through the BT all the time and it sounds great... Quote Link to post Share on other sites
VBLUE42 Posted June 22, 2010 Report Share Posted June 22, 2010 Do i need to set it to aux or something? Plug it into the AV2 input and set that input to VIDEO in the settings. USB may also work with the unit as a USB drive if the phone supports USB audio. Quote Link to post Share on other sites
rrolff Posted June 22, 2010 Report Share Posted June 22, 2010 I ditched my iPhone last week for the MyTouch slide (Android 2.1). When plugged in via USB, I get the message "The USB Memory cannot be used on this device" - or something to that effect... Not sure if that may have something to do with the type of memory in the phone (32GB SDHC card) - I know the phone looks like a thumb drive on my PC... Bluetooth is well integrated, and works nicely... Quote Link to post Share on other sites
matty dread Posted June 22, 2010 Author Report Share Posted June 22, 2010 i'll try the bluetooth again. it didn't sound as good but maybe I didn't set it up correctly. Quote Link to post Share on other sites
matty dread Posted July 9, 2010 Author Report Share Posted July 9, 2010 okay, I went back to trying to get the bluetooth to work and I get a message that says "try making the connection from the phone first" or something like that. is there an order I need to pair these in? should I delete the droid then re-add it from the phone side? I am thinking this shouldn't be this hard but apparently something is not happening correctly. Quote Link to post Share on other sites
thedak1 Posted July 28, 2010 Report Share Posted July 28, 2010 If I'm reading your post right I think the unit wants you to search for it from your phone. Quote Link to post Share on other sites
cx650t Posted November 16, 2010 Report Share Posted November 16, 2010 okay, I went back to trying to get the bluetooth to work and I get a message that says "try making the connection from the phone first" or something like that. is there an order I need to pair these in? should I delete the droid then re-add it from the phone side? I am thinking this shouldn't be this hard but apparently something is not happening correctly. Go into the Z's bluetooth settings and delete the phone. Then make sure that buletooth is turned on in the Droid. (Check under wireless settings.) Then go back on the Z and tell it to connect to "phone and audio" and the two should link up. Select Bluetooth for the audio source. Fire up your audio player on the Droid and it should start streaming to the Z. On my i1 I have no control over the droid from the Z. I also don't get any information (song title/artist) on the Z's display. My i1 also doesn't work when connected to the USB. Z claims the storage is unsupported yet it works fine on my Pc using either Linux or W$. The droid will charge from the USB port so you can use it to stream like a radio station of old. Just enjoy the music. Quote Link to post Share on other sites
VBLUE42 Posted November 17, 2010 Report Share Posted November 17, 2010 You cant delete paired phones from the BT settings screen. You have to do a full reset on the unit. Quote Link to post Share on other sites
cx650t Posted November 17, 2010 Report Share Posted November 17, 2010 You cant delete paired phones from the BT settings screen. You have to do a full reset on the unit. If you don't know what you're talking about please refrain from posting your worthless drivel. Click on Bluetooth. Click on connected devices Click on disconnect. Then click on pair. Click on Handsfree and Audio. As to disconnecting a Bluetooth device check out page 66 of the manual. No need to do any reset. Quote Link to post Share on other sites
VBLUE42 Posted November 17, 2010 Report Share Posted November 17, 2010 Its amazing how stupid you look right now. Quote Link to post Share on other sites
CaptainInsaneO Posted November 17, 2010 Report Share Posted November 17, 2010 Its amazing how stupid you look right now. While I agree that his rudeness makes him look like a jackass, vblue, he's actually correct about Page 66. That being said, stop acting like a dick, cx. It will get you booted from the forum. Quote Link to post Share on other sites
VBLUE42 Posted November 17, 2010 Report Share Posted November 17, 2010 No he's not! The OP of this thread has a 110 and page 66 of the manual for the 110 has nothing to do with deleting paired phones on that unit. It does for the 120 but that proceeder will not even apply if there are not five paired phones on the unit and even then it wouldn't work as described on the 110. The only way to remove a paired phone on these units is to do a reset. And that is the only solution if the paired phone does not work properly and even then that may not do the trick. Quote Link to post Share on other sites
cx650t Posted November 17, 2010 Report Share Posted November 17, 2010 No he's not! The OP of this thread has a 110 and page 66 of the manual for the 110 has nothing to do with deleting paired phones on that unit. It does for the 120 but that proceeder will not even apply if there are not five paired phones on the unit and even then it wouldn't work as described on the 110. The only way to remove a paired phone on these units is to do a reset. And that is the only solution if the paired phone does not work properly and even then that may not do the trick. In the words of Steve Martin, "Well excuse me". Sounds more like the pot calling the kettle black. It's on page 82 of the 110 manual and you still don't know what you're talking about. Quote Link to post Share on other sites
VBLUE42 Posted November 17, 2010 Report Share Posted November 17, 2010 Ok, you have 9 post now and you have the nerve to tell me I don't know what I am talking about. Stupid noob. Quote Link to post Share on other sites
