va_connoisseur Posted December 18, 2006 Report Share Posted December 18, 2006 I plan to remove the Yellow/Black cellular mute wire and use it for the bypass ground wire. For all of you that have done the bypass, what is the best (read: easiest) method of removing the wire from the harness? I'm trying to make this as smooth as possible. Thanks in advance. Quote Link to post Share on other sites
cntrylvr79 Posted December 19, 2006 Report Share Posted December 19, 2006 Though many people will probably say don't, I've always just given the wire a nice tug. Never ripped the connector off either. Quote Link to post Share on other sites
kenchar Posted December 19, 2006 Report Share Posted December 19, 2006 I used a small jewellers screw driver and gently pried the it out. If you look closely and push/pull on the wire, you can see the part that holds it into the plug. I released mine with the small jewelers screw driver and when I installed it made sure it locked in. Sorry my description is so vague but it has been a bit since I did it. Quote Link to post Share on other sites
C6 Guy Posted December 20, 2006 Report Share Posted December 20, 2006 Though many people will probably say don't, I've always just given the wire a nice tug. Never ripped the connector off either. Ditto. I fiddled with some very small screwdrivers and a paperclip for a while and gave up. It came out with a decent yank. Quote Link to post Share on other sites
