Isaac007 Posted January 2, 2007 Report Share Posted January 2, 2007 I paid to have my D2 installed. Yes, I know. But I had to have custom dash work done that I didn't want to do. Anyway, I had them do the bypass for me. I thought it was working when I left, but after I got 100 miles away I realized it wasn't working! The installer didn't want to get in trouble so he put in a toggle switch that supposedly grounds the parking brake. When the unit is turned on, it gives the improper parking brake install warning. Also, when the toggle is switched off, you can't do anything (like you are driving). When it is switched on, it behaves as if the brake is on until you start driving. I had the mute wire in the extra slot when I gave him the harness and told him to ground it. Just curious if anyone had any suggestions since I am taking it back to get them to fix something else they messed up too. Is it possible they just didn't ground the extra wire? Oh yeah, I had the bypass relay on it to begin with. But the first shop I took it to cut it off, and I didn't know how to reattach. A$$holes... Quote Link to post Share on other sites
tillithz Posted January 2, 2007 Report Share Posted January 2, 2007 well, Im retarded! the toggle switch would have to provide ground to both the extra wire and the parking brake at the same time. Quote Link to post Share on other sites
Isaac007 Posted January 2, 2007 Author Report Share Posted January 2, 2007 Oh yeah, I'm kind of curious if they actually hooked up my VSS or reverse wires too. How can I check that without tracing wires? thanks Quote Link to post Share on other sites
tillithz Posted January 2, 2007 Report Share Posted January 2, 2007 i believe but could be wrong, that when the unit is bypassed, if the vss wire is not hooked up, you wont get a reading on the speedo, i could be wrong though as I havent tested this. Quote Link to post Share on other sites
action Posted January 2, 2007 Report Share Posted January 2, 2007 i believe but could be wrong, that when the unit is bypassed, if the vss wire is not hooked up, you wont get a reading on the speedo, i could be wrong though as I havent tested this. I just posted about this elsewhere, but I don't think my vss wire is hooked up because the speed sensor always reads 0. However, I spedometer still gives me a reading. Quote Link to post Share on other sites
tillithz Posted January 2, 2007 Report Share Posted January 2, 2007 then likely not hooked up cause speed is obtained from gps i believe as well. Quote Link to post Share on other sites
sportsfan21 Posted January 2, 2007 Report Share Posted January 2, 2007 tillithz- The ducati, october bypass, flashing lights thing is ONLY for the Z1. The OP clearly stated he has a D2. Quote Link to post Share on other sites
tillithz Posted January 2, 2007 Report Share Posted January 2, 2007 /me is retarded and cant read Quote Link to post Share on other sites
Isaac007 Posted January 11, 2007 Author Report Share Posted January 11, 2007 Genius just forgot to ground the extra wire. I did it... no big deal. Thanks Quote Link to post Share on other sites
