jobewan Posted January 10, 2007 Report Share Posted January 10, 2007 I've had the Z1 installed and working now for a month or so and am pretty impressed with its performance, sound etc. Except for some of the common problems discussed here I'm a satisfied customer. And, I gotta say this group has been GREAT in helping and I thank everyone for their input. Now, my next question is "how do I turn things off?". When I select the off option in the AV screen it shuts down the sound, but I don't seem to be getting a remote signal that turn my amps off. I haven't checked it with a meter, but, I know tha amp responded to the remote signal with its previous head unit. That means I live with a little bit of hiss/noise from my system's imperfections when I need a moment of peace and quiet. I have looked pretty carefully throught the manual and in the forum but haven't seen much on "off". Any help or ideas about this would be a great help. thanks, Joe Quote Link to post Share on other sites
tech10002 Posted January 10, 2007 Report Share Posted January 10, 2007 Mine does the same thing. The remote turn on lead is always hot anytime the key is on, so the amps are always powered up. You can't use the power antenna lead either since it's only hot when the FM/AM tuner is selected. Quote Link to post Share on other sites
whtcrxghst Posted January 10, 2007 Report Share Posted January 10, 2007 The remote turn on stays active on purpose. Its designed to still give you navigation instructions even when you have it sourced off. That leaves you a couple of choices--fix your noise problems OR install a switch on the remote turn on lead letting you control when its on or off Quote Link to post Share on other sites
OSUV Posted January 10, 2007 Report Share Posted January 10, 2007 whtcrxghst is correct. There is no actual off on the Z1. It's more like a standby or hibernate mode, but the system is always on. Your best option is to install a cutoff switch inline with the wire that powers your amp(s). Quote Link to post Share on other sites
jobewan Posted January 10, 2007 Author Report Share Posted January 10, 2007 The remote turn on stays active on purpose. Its designed to still give you navigation instructions even when you have it sourced off. That leaves you a couple of choices--fix your noise problems OR install a switch on the remote turn on lead letting you control when its on or off I guess that makes some kind of sense. Having voice navigation instructions available all the time, even when no navigation is occurring seems a bit extreme. As for "fixing" my noise problems, I'm not sure how. The diesel in the F-350 apparently puts out a lot of noise. I've got all the power wires running in a straight line to the amps under the carpet, a single ground block bolted to the chassis for all amps installed within a foot of them, and noise filters at the inputs side of the amps on the shielded signal wires that are run under the doors on the driver side. I suppose I could ground the shields on the signal wires but don't hold high hope for getting rid of "all" the noise. Its not noticeable when the head unit is playing music unless it is set very low. But, when it is "hibrinating" it is audible. Joe Quote Link to post Share on other sites
