nitronick Posted May 4, 2011 Author Report Share Posted May 4, 2011 You're not going to harm anything just by looking through folders. I think the maps are in APL2 if my memory is correct. Chris. Chris, You are correct.... APL2/iGO/Content/MAP I'm halfway thruogh downloading the US maps as soon as I have all of them I will extract them all to a folder on my desktop and switch them out with the EW maps on the backup files...I have them already extracted to an SD card. then I will let you all know. Thanks Again! Nick Quote Link to post Share on other sites
charliecharlie Posted May 5, 2011 Report Share Posted May 5, 2011 Nick, when you've got it up and running don't forget to keep a copy of the un-modded 'my flash disk' on your pc in case you stuff the AVIC again in the future (although after what you've been through I can't imagine that happening!)lol Chris. ps do you really need all of the US maps? I would just download the ones you need & add the rest as required. Quote Link to post Share on other sites
nitronick Posted May 5, 2011 Author Report Share Posted May 5, 2011 Nick, when you've got it up and running don't forget to keep a copy of the un-modded 'my flash disk' on your pc in case you stuff the AVIC again in the future (although after what you've been through I can't imagine that happening!)lol Chris. ps do you really need all of the US maps? I would just download the ones you need & add the rest as required. I really do need all of the us maps...besides once this thing is up and running I wanna leave it alone for a while! LOL Yes once I verify the files work I'm gonna back it up. Quote Link to post Share on other sites
nitronick Posted May 6, 2011 Author Report Share Posted May 6, 2011 Well, Everything was looking good....got all the Maps,Poi's and DEMs swapped over removed all EW Maps followed the instructions....got everything started....watched as is was loading everything....it got just past the POI's and threw an error of not enough space leftand to delete items to make space. So I shut it down took the SD car back in and put it in my PC and deleteted the EW POI's and tried again....it got further but did the same thing...so I went back in and deleted the EW buildings and quite a few EW langauges I left UK english,AU english and Spanish. went back out tried again but this time it will not start up in testmode it just throws the pioneer screen and restarts every 20-30 seconds but looks like it's trying to read the SD i'm getting the bluetooth light flashing. I went back in and deleted the 2.3 testmode from my SD card and extracted it on again. I tried clearing the SD card completly and re-extracting the EW backup files and changing only what I did the 2nd time to no avail. I'm kinda stuck here anybody have any Ideas? Only thing I think I might have done different was not removing the SD card before shutting of the key not sure if I did or not. I even tried to load testmode 2.3 onto an SD by itself figuring if I could get it into testmode then swap cards I might be alright....nope! This thing is bumming me out! (checked again and now it shows pioneer sceen..the bluetooyh light flashes 3 times them it shuts down....blacked out brick) Quote Link to post Share on other sites
charliecharlie Posted May 7, 2011 Report Share Posted May 7, 2011 keep trying, it took me a couple of attempts before I got it. When I did my install I didnt do the 'unmount the disk' bit because you're already formatting it. Keep going, you're nearly there. Chris. Quote Link to post Share on other sites
nitronick Posted May 7, 2011 Author Report Share Posted May 7, 2011 Thanks for the incouragement! I took the original 3.0 DL loaded it up and it got me back into testmode once there I swapped SD to the EW backup files and did the EW copy/paste and again it warned of not enough disk space...so I popped the SD back in the PC and slashed and burned the US POI's the EW Voices,Buildings and POI's...put it back in copy/paste ect....this time it did not warn of free space so I let her rip....it loaded up everything. I followed the instructions...remove SD card,shut off car...with car off install 2nd SD card and restart car.Well it brought up the Update screen in red and was "file searching" for over 30 min. and in the lower bar it said incorrect information on SD/USB! so close! So right now it will start up to main menu but the system start up bars stays on. The radio/CD works but it restarts after 2-5 mins it allows me access to the settings and shows ver, 3.0 but it won't go to GPS/maps it just gives the Nav warning screen and it shuts down. Right now I'm re-downloading the update from the EW backup files thread to see if I somehow corrupted the original while loading and unloading these SD cards. Any other Ideas? was it ok to remove all of the POI's,Buildings,Language and Voices? Thanks Again Chris, I was very close to placing this unit gently under a bus tire! Quote Link to post Share on other sites
charliecharlie Posted May 8, 2011 Report Share Posted May 8, 2011 Just make sure you reformat your sd card each time. Removing poi's etc is not a problem. Did you rename the rar files as instructed? I wish I was there to walk you through it! Chris Quote Link to post Share on other sites
nitronick Posted May 8, 2011 Author Report Share Posted May 8, 2011 Just make sure you reformat your sd card each time. Removing poi's etc is not a problem. Did you rename the rar files as instructed? I wish I was there to walk you through it! Chris Ok, I did not re format the SD card before switching over from the old 3.0 to the pioneer update.I did rename and rar the EW files. I give the reformat a try. Nick Quote Link to post Share on other sites
nitronick Posted May 8, 2011 Author Report Share Posted May 8, 2011 Ok, I did not re format the SD card before switching over from the old 3.0 to the pioneer update.I did rename and rar the EW files. I give the reformat a try. Nick I reformated the SD and reloaded the update on it and am still getting "incorrect software on SD/USB" is there another update I should be using? Thanks Nick Quote Link to post Share on other sites
nitronick Posted May 10, 2011 Author Report Share Posted May 10, 2011 I got it!!! Ok, the answer was right in front of me the whole time I was really stuck on the EW backup files...I reallized after looking thru the US 3.0 files from my original botched uddate that all of the maps,lang,voice,poi's...ect. were right there...so I followed the same procedure for the EW install...format,copy/paste ect. Huge Thanks to Chris ya kept me going! and everyone else on this forum! Now....should I install the dafiata's mod? It's ready to load on an SD. The instructions say to reboot THEN remove the SD card. I want to be clear and not cause myself another situation. Reboot simply means turn the key off then restart correct? Thanks again! Quote Link to post Share on other sites
charliecharlie Posted May 10, 2011 Report Share Posted May 10, 2011 Way heyyyy! Well done! Diaftia's mod makes the AVIC more useable and you can personalise it to suit your needs. And just follow his instructions. Remember to keep that copy of 'my flash disk' safe in case you ever want to go back to the original firmware. And reboot means restart! That tiny little reset button just returns all your settings to factory default. If I'd realised you still had all the files from your US version3 you'd have been up & running days ago! Well done again! Chris. Quote Link to post Share on other sites
nitronick Posted May 10, 2011 Author Report Share Posted May 10, 2011 Way heyyyy! Well done! Diaftia's mod makes the AVIC more useable and you can personalise it to suit your needs. And just follow his instructions. Remember to keep that copy of 'my flash disk' safe in case you ever want to go back to the original firmware. And reboot means restart! That tiny little reset button just returns all your settings to factory default. If I'd realised you still had all the files from your US version3 you'd have been up & running days ago! Well done again! Chris. Thanks! Much better...I went from version 1.0 to 3.0 and WOW! Now I push the touch screen and it actually does something almost right away no more lag! It seems to boot up faster aswell. I will try the Diaftia mod tonight. I made a back up of my flash disk already. Thanks for all the help Chris! Nick I really meant it when I said I had very basic comp skills. I just took a blind shot and scored. Quote Link to post Share on other sites
