RonS Posted May 7, 2012 Report Share Posted May 7, 2012 Make sure you install the ShortFuse hack using the Pioneer 1.001 patch release. If you are still running the original Z110 software, it will ignore the 2.00x patch files. So, you need the original Shortfuse files to patch 1.001 - and when done will report as 1,003 - IIRC. Once that is installed - re-verify the version number as before. Then you should be good to install CNSD-210FM SD1. Copy the contents of your extracted SD1 folder (ie Firmware, Update, and cardinfo.cfi) to the root of your SD. Quote Link to post Share on other sites
hateplow Posted May 7, 2012 Report Share Posted May 7, 2012 Ok. Ill look that up after work. Thank you rons Quote Link to post Share on other sites
Gtr917punk Posted May 7, 2012 Report Share Posted May 7, 2012 im sorry guys but where can i find the shortfuse hack for an avic-z110bt with stock fw currently on it? Quote Link to post Share on other sites
hateplow Posted May 8, 2012 Report Share Posted May 8, 2012 Ok bt fw is 3.22 Version 3.0000 Platver 3.000 Appver 3.001 Is that all correct now? Â Grt917punk is a couple threads below this one. Quote Link to post Share on other sites
RonS Posted May 8, 2012 Report Share Posted May 8, 2012 Ok bt fw is 3.22 Version 3.0000 Platver 3.000 Appver 3.001 Is that all correct now? Â Grt917punk is a couple threads below this one. Great - you're done. Quote Link to post Share on other sites
hateplow Posted May 8, 2012 Report Share Posted May 8, 2012 thanks you very much for the help RonS Quote Link to post Share on other sites
lucho3410 Posted May 12, 2012 Report Share Posted May 12, 2012 AM I bricked. I have a z110bt. Did the shortfuse crack. I never really checked my firmware version after that, i assumed it worked because the unit restarted after it finished and no problems occured. I then went ahead and tried the CNSD 210fm and inputed PASSWORDPASSWORD and updated all through 98% then got a update fail. I tried putting sd card again and said update fail retry but nothing happens when i hit retry. I used 8g micro SD on sd adaptor to do both shortfuse and update (reformatted card between updates). I've been stuck on that screen for a while now. I'm able to reboot to testmode however, but i cant do any forcewrite because it doesnt read sd card or usb slot. I then went ahead and got me a 4g sd card thinking that could be it but no go still. I'm going to try another PC to format and retry but maybe theres something else i can try? If u have any suggestions, PLEASE SHARE! Â THANX Quote Link to post Share on other sites
GONZOcobalt Posted June 15, 2012 Report Share Posted June 15, 2012 Yeah, downloading will take a while, but I've waited this long, what's another day? Â In the meantime, we now have a reason to implement "The Password Hack" while we wait. Yeah, downloading will take a while, but I've waited this long, what's another day? Â In the meantime, we now have a reason to implement "The Password Hack" while we wait. How do i do the password hack? i have the cnsd-210fm downloaded already but how do i crack the password. mines just a plain z110bt no upgrades. I've been trying to find it and i can't. Quote Link to post Share on other sites
GONZOcobalt Posted June 15, 2012 Report Share Posted June 15, 2012 Yeah, downloading will take a while, but I've waited this long, what's another day? Â In the meantime, we now have a reason to implement "The Password Hack" while we wait. how do you do the password hack? i have cnsd-210fm downloaded already but i don't know what to do to do the rest. i just have a plain z110bt. I've been trying to find it and i can't. thanks Quote Link to post Share on other sites
dinan5m3 Posted July 4, 2012 Report Share Posted July 4, 2012 Is there any reason to think that after CNSD-210FM upgrade (eg. on AVIC-Z120BT) that you will loose the bypass (with mute wire) capability? Thanks. Quote Link to post Share on other sites
dinan5m3 Posted July 4, 2012 Report Share Posted July 4, 2012 Is there any reason to think that after CNSD-210FM upgrade (eg. on AVIC-Z120BT) that you will loose the bypass (with mute wire) capability? Thanks. Â VBLUE42 answered it here, http://avic411.com/index.php?/topic/33473-z120-upgraded-to-z130-bypass-doesnt-work/page__view__findpost__p__251620 Quote Link to post Share on other sites
mlrtimev6 Posted August 11, 2012 Report Share Posted August 11, 2012 looks like I'm having problems with shortfuse's crack to 1.003... I'll keep playing Quote Link to post Share on other sites
mlrtimev6 Posted August 12, 2012 Report Share Posted August 12, 2012 Wow.... almost 10 hours into this. I had one of the infamous units where the service information will ONLY show v1.001 even though 2 has gone though. Quote Link to post Share on other sites
zarquan Posted August 20, 2012 Report Share Posted August 20, 2012 Thanks everyone who put this together and provided instructions! I recently bought a car with a z110bt installed but never upgraded and you made this a fast and easy upgrade. Â I installed the shortfuse crack on update 1.001 and stuck in the SD card and it updated. Then I copied the SD1 folder from CSND-210 onto the sd-card, stuck it back in and it updated again. With that card still in I updated the bluetooth firmware. Then I put the contents of the SD2 folder on and updated the bluetooth firmware again. Quote Link to post Share on other sites
rodotre Posted August 30, 2012 Report Share Posted August 30, 2012 does this update have mexico maps on it Quote Link to post Share on other sites
