pghjerry Posted October 21, 2011 Report Share Posted October 21, 2011 Is there any way to remove pressing OK each time you turn on the radio? Surely I can't be the only one that is sick of agreeing to whatever the screen says every time you start the car, lol. Quote Link to post Share on other sites
elektrik Posted December 29, 2011 Report Share Posted December 29, 2011 I fixed mine with a custom firmware... Quote Link to post Share on other sites
NY8 Posted December 30, 2011 Report Share Posted December 30, 2011 I fixed mine with a custom firmware... Got it from somewhere or modded it yourself? Quote Link to post Share on other sites
gmac78 Posted December 31, 2011 Report Share Posted December 31, 2011 Got it from somewhere or modded it yourself? Haha you need to tell us more ! Quote Link to post Share on other sites
ronsno Posted December 31, 2011 Report Share Posted December 31, 2011 I fixed mine with a custom firmware... I'll pay you for the fix:) Quote Link to post Share on other sites
elektrik Posted January 1, 2012 Report Share Posted January 1, 2012 Got it from somewhere or modded it yourself? Nope, I got it here. I used the FX 3.1 firmware.... http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/ Quote Link to post Share on other sites
maccrap Posted January 1, 2012 Report Share Posted January 1, 2012 When you say used, what do you mean exactly? I'd like to do this myself Quote Link to post Share on other sites
grradams Posted January 2, 2012 Report Share Posted January 2, 2012 Nope, I got it here. I used the FX 3.1 firmware.... http://avic411.com/i...firmware-image/ Yes, the guides on that thread are for other radios than the appradio so the instructions for button presses and methods don't apply to our radios. What steps did you do to get it to work on your appradio? Quote Link to post Share on other sites
Crakavelli Posted January 3, 2012 Report Share Posted January 3, 2012 Clearly he was posting in the wrong forum, got everyone excited for no reason Quote Link to post Share on other sites
Crakavelli Posted January 3, 2012 Report Share Posted January 3, 2012 He was referencing a post from early 2010, the appradio wasn't even released yet Quote Link to post Share on other sites
grradams Posted January 3, 2012 Report Share Posted January 3, 2012 son of a! haha Quote Link to post Share on other sites
aslpa Posted January 24, 2012 Report Share Posted January 24, 2012 it works with custom re-pack.... interface only in russian, if you want i will post link here Quote Link to post Share on other sites
Vendigroth Posted January 25, 2012 Report Share Posted January 25, 2012 it works with custom re-pack.... interface only in russian, if you want i will post link here I'd like a link Quote Link to post Share on other sites
aslpa Posted January 25, 2012 Report Share Posted January 25, 2012 sorry, i'm use google translate for repack instructions... "AppRadio + - build additional configuration, scripts and programs that enhance series Pioneer units AppRadio (model SPH-DA01). AppRadio + provides the following capabilities: - Launch of external navigation software in conjunction with regular operating envelope, - Connect to the Internet using an external usb-modem as a modem, mobile phones can act, gprs-modem, cdma-modem, etc. - Launch other external programs that the user requires. I thank all the participants of the forum 4pda.ru for assistance in the preparation of this assembly, and special thanks to: carver_ua, Shtorm (3ppc.net), MalVal, djskam. To connect the modem using usb-port for iphone, pre-attaching an usb-hub, may also need to add. power to iphone, connected through a hub, could be charged if there is a hub of other devices. Thus, a hub can poklyuchat usb-stick and other devices. In order to have earned the phone (usb-modem) on the usb-connection as a modem for Internet access should be added to the assembly prior to its installation on the machine settings for your phone (modem). To define the settings for a particular model phone (modem), as described here do You can also read here how to pick up your phone to work with the driver used. After that, you should get the reg-file that defines the settings for your phone, its structure should be as follows: REGEDIT4 # Instead will be given your XXXX_YYYY_Z numbers that correspond to your phone [HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z] [HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default] [HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default \ Default] [HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default \ Default \ RS23 2_USB] "Index" = dword: 00000009 # defines to which port to start the initialization "FriendlyName" = "USB modem" # here should be the name of the device may be any and it will be used in the connection settings as the name of the modem "UsbMode" = dword: 00000000 "SendEndp" = dword: 00000002 # important parameter, it determines the right to use your phone as a modem "ReceiveEndp" = dword: 00000082 # important parameter, it determines the right to use your phone as a modem "ClassEndp" = dword: 00000081 # important parameter, it determines the right to use your phone as a modem "DeviceType" = dword: 00000001 "Tsp" = "Unimodem.dll" "Prefix" = "COM" "Dll" = "232usb.dll" # check that the name of the dll mentioned here as Place the resulting file to a folder AppRadio \ System \ Registry under any name with the extension reg Setup and installation of the assembly Important: The current version of the assembly will only work with version 2.22 firmware device, if you have another version, the official firmware update as usual. Carefully read the description of the set up and run an assembly: Spoiler (+/-) 1. Unpack the archive to the memory card in the root directory cards shall be placed AppRadio and files: - Cetool66.exe - Cetool66.mscr - Mortscript.exe - Toolhelp.dll 2. Insert the card into the machine and reboot the device (do a hard reset), and the machine should be booting in safe mode and will launch testmode installer assembly. 3. Follow the installation instructions, the first installation of the assembly is recommended first to claim 1, "Installing the Assembly." 4. After successful installation, you must re-do a hard reset the device (the installation program will remind you about this before the release). 5. After installation, assembly loading apparatus must pass regular way (with the screen may momentarily appearance of programs to run in addition to the functioning of the assembly). On subsequent inclusions apparatat should also automatically clicks OK on the standard warning that appears at startup. 6. Log in extended menu by pressing the button on the standard settings (in order to still get into the settings to exit the advanced menu on the 'Heads. Menu "from the top bar). The expanded menu is implemented in the style of the iPhone and AppRadio and allows you to scroll the screen horizontally. 7. The expanded menu is implemented by the application iPhoneToday. In the current implementation, customization, adding, deleting programs is possible only by correcting the configuration file: icons.xml, system.xml, are to assemble at: AppRadio \ System \ Menu \ For the changes to take effect, the corrected files to be added to the assembly and make it update by running Setup from the expanded menu. 8. To set up Internet connections, you must run "App. is connected. "from the top bar menu and an extended follow its instructions. To the selected connection is established automatically assign it to the status of "active compound". 9. For automatic initialization and control of the compound is in the process of program "Connector" in the top bar. It also starts automatically when you first start the navigation software using the Internet connection (it is set up in launching the navigation program script). 10. Navigation and other programs should be in a folder at the root of APL SD-card, USB-flash drives or in memory (NAND FLASH), the initial startup scripts are set to this folder." - Serhy AppRadio_plus_01.rar Quote Link to post Share on other sites
Vendigroth Posted January 25, 2012 Report Share Posted January 25, 2012 sorry, i'm use google translate for repack instructions... Could I have a link to the original thread? If i Have to register somewhere that's no problem, i just don't know if i should be looking through 4pda.ru or 3ppc.net. Quote Link to post Share on other sites
