IIIRAMOIII Posted May 24, 2013 Report Share Posted May 24, 2013 the one problem i have (even before this upgrade) is that Pandora doesnt work in advanced app mode. it this a common issue? Link to post Share on other sites
saiojitsu Posted May 24, 2013 Report Share Posted May 24, 2013 I installed your tweak by cydia. I've iphone 4 with 5.1 jailbroken and mobile substrate and applist installed. Why i've few options in appradio extension setting? in many video i see more option. Why me not? Link to post Share on other sites
Tomfoolery82 Posted May 25, 2013 Report Share Posted May 25, 2013 Works good but sometimes the screen is smaller with the triangles on the side. Makes the the keyboard calibration off for me. Also music widget app used to work now it crashes the phone only when connect to app radio. Anybody know how to put a Siri icon on their home screen. 4s 6.1.2 app radio 2 fw 8.17 app 2.3.0 beta 12 Beta 10 had no screen resizing issues. I use sbrotator to rotate spring board and apps works well but when springboard launches the phone rotates (activator when plugged in) but on the app radio it's rotated but vertical. I have to launch the music app to rotate the springboard to landscape. Link to post Share on other sites
Aleraco Posted May 25, 2013 Report Share Posted May 25, 2013 Works good but sometimes the screen is smaller with the triangles on the side. Makes the the keyboard calibration off for me. Also music widget app used to work now it crashes the phone only when connect to app radio. Anybody know how to put a Siri icon on their home screen. 4s 6.1.2 app radio 2 fw 8.17 app 2.3.0 beta 12 Beta 10 had no screen resizing issues. I use sbrotator to rotate spring board and apps works well but when springboard launches the phone rotates (activator when plugged in) but on the app radio it's rotated but vertical. I have to launch the music app to rotate the springboard to landscape. same behaviour for me. (resizing issue).the screen is scaled down a bit on some app. 4s 6.1.2 sphda-02 4.16 app 2.3.0 beta 12 Link to post Share on other sites
mikedecaro Posted May 25, 2013 Author Report Share Posted May 25, 2013 Works good but sometimes the screen is smaller with the triangles on the side. Makes the the keyboard calibration off for me. Also music widget app used to work now it crashes the phone only when connect to app radio. Anybody know how to put a Siri icon on their home screen. 4s 6.1.2 app radio 2 fw 8.17 app 2.3.0 beta 12 Beta 10 had no screen resizing issues. I use sbrotator to rotate spring board and apps works well but when springboard launches the phone rotates (activator when plugged in) but on the app radio it's rotated but vertical. I have to launch the music app to rotate the springboard to landscape. Does the screen size issue happen all of the time? only when using unsupported apps? Link to post Share on other sites
str8wick3d Posted May 25, 2013 Report Share Posted May 25, 2013 Hey man good job, I think you should add a weather Icon that shows the temps to homescreen, would be boss shit Link to post Share on other sites
Tomfoolery82 Posted May 25, 2013 Report Share Posted May 25, 2013 unsupported apps. I dont really use the supported ones any more. I use iOS instead of pioneers OS. I like using the springboard Link to post Share on other sites
Aleraco Posted May 25, 2013 Report Share Posted May 25, 2013 same behaviour for me. (resizing issue).the screen is scaled down a bit on some app. 4s 6.1.2 sphda-02 4.16 app 2.3.0 beta 12 + Ios Keyboard calibration is loss with whatsapp Link to post Share on other sites
churchn Posted May 26, 2013 Report Share Posted May 26, 2013 I am having problems getting any of the functions of AppRadio Extensions to work. I have AppRadio SPH-DA02 AppRadio App Version 2.3.0 App EXT Version 2.0.1-1 AppRadio FW 4.16 Apple 4 -jailbroken running 5.1.1 I don't know if it has something else installed on my phone that is not making it possible to use AppRadio Extensions. I have read through several posts and found no help. I was wondering if anyone else is having/had issues similar to mine and if so what was done to resolve the issues? Link to post Share on other sites
mikedecaro Posted May 26, 2013 Author Report Share Posted May 26, 2013 I am having problems getting any of the functions of AppRadio Extensions to work. I have AppRadio SPH-DA02 AppRadio App Version 2.3.0 App EXT Version 2.0.1-1 AppRadio FW 4.16 Apple 4 -jailbroken running 5.1.1 I don't know if it has something else installed on my phone that is not making it possible to use AppRadio Extensions. I have read through several posts and found no help. I was wondering if anyone else is having/had issues similar to mine and if so what was done to resolve the issues? You need version 1.8.2 of the AppRadio app. Check out the FAQ. Link to post Share on other sites
churchn Posted May 26, 2013 Report Share Posted May 26, 2013 Thank you for the quick reply. What you are doing here is greatly appreciated. I tried 1.8.2 a couple of days ago with no success but I wasn't running the 4.16 FW update at the time. I will try again. Thank you Link to post Share on other sites
churchn Posted May 26, 2013 Report Share Posted May 26, 2013 Works great, thank you Mike Link to post Share on other sites
evodris Posted May 26, 2013 Report Share Posted May 26, 2013 So it looks like there is a new Backgrounder app in Cydia called Backgrounder Manager. Time to test it out with the app radio!!! Hopefully Mike can use this for his extension! I've been playing with it for a little bit and it seems to work ok... sometimes I have to reconnect my cord for it to display on the app radio though.. Will do more testing tomorrow Link to post Share on other sites
chpopel Posted May 26, 2013 Report Share Posted May 26, 2013 i have a iphone 4S running 6.1.3 os. Is there any way i can use app radio extensions? i have a pioneer app radio 2. Link to post Share on other sites
bear52885 Posted May 26, 2013 Report Share Posted May 26, 2013 I know it's up and running now but wasn't sure if maybe this would help. There is background manager now in cydia that is a backgrounder for iOS 6 Link to post Share on other sites
