S.A.M. Posted June 5, 2013 Report Share Posted June 5, 2013 thanks, I got most of it squared away I think. You'll be fine with Redsnow if you're only using the phone in the car with the Pioneer. My jailbroken iPod touch running iOS 6.1.3 and Rednow only rarely needs to be rebooted with some Cydia app upgrades, otherwise totally stable. Link to post Share on other sites
Clarity2431 Posted June 6, 2013 Report Share Posted June 6, 2013 Ok so I've been following this thread for a while and it was one of the primary reasons why I purchased the AVH-X7500BT Pioneer head unit. I just got my system installed this past weekend and I just started messing with the AppRadio last night. I seem to be running into issues however. When I start up AppRadio and try to click on Maps or even Photos it tells me the car must be parked. Not only was I parked and not even moving, but when I had my system installed I made sure the Parking Brake was bypassed. Does anyone have any idea as to why this would be happening? I even got the CarBrowser app and was trying that out and I managed to get it to pop up once but it usually gave me the same message as the other apps...Any help would be appreciated. Thanks and I look forward to hearing back from you guys! Link to post Share on other sites
WRS Posted June 6, 2013 Report Share Posted June 6, 2013 Ok so I've been following this thread for a while and it was one of the primary reasons why I purchased the AVH-X7500BT Pioneer head unit. I just got my system installed this past weekend and I just started messing with the AppRadio last night. I seem to be running into issues however. When I start up AppRadio and try to click on Maps or even Photos it tells me the car must be parked. Not only was I parked and not even moving, but when I had my system installed I made sure the Parking Brake was bypassed. Does anyone have any idea as to why this would be happening? I even got the CarBrowser app and was trying that out and I managed to get it to pop up once but it usually gave me the same message as the other apps...Any help would be appreciated. Thanks and I look forward to hearing back from you guys! Your parking brake is not bypassed. Link to post Share on other sites
Clarity2431 Posted June 6, 2013 Report Share Posted June 6, 2013 Your parking brake is not bypassed. Why would it give me that message if I was parked then? Link to post Share on other sites
oneyozfest182 Posted June 6, 2013 Report Share Posted June 6, 2013 Why would it give me that message if I was parked then? Whoever hooked your deck up didn't hook the e-brake wire up correctly or something. Link to post Share on other sites
WRS Posted June 6, 2013 Report Share Posted June 6, 2013 Why would it give me that message if I was parked then? do you set your parking brake according to the instructions? There is a whole thread on this. Link to post Share on other sites
Clarity2431 Posted June 6, 2013 Report Share Posted June 6, 2013 Ok thanks for the input guys. I'm taking it in to have it looked at today. Clearly he did something wrong. I was testing the AppRadio feature when I first noticed problems but, after you guys suggested it wasn't properly hooked up, I threw a DVD in there and I could only hear audio but no video and it clearly says in the manual that the parking brake cable isn't connected. Thanks again for the help...can't wait to mess with this AppRadio! Link to post Share on other sites
chino73 Posted June 9, 2013 Report Share Posted June 9, 2013 Did someone use the external GPS antenna successfully with non supported apps? I remember reading somewhere that it doesn't work but just wanted to make sure. Thanks in advance! Link to post Share on other sites
Candyfloortrash Posted June 9, 2013 Report Share Posted June 9, 2013 Any idea on how to get an i5 to work with AR1? Sick of using my iPod... Thanks! Link to post Share on other sites
VBLUE42 Posted June 9, 2013 Report Share Posted June 9, 2013 There will no support for video or app mode for DA01/02 units. Link to post Share on other sites
mikedecaro Posted June 9, 2013 Author Report Share Posted June 9, 2013 Just posted an update: Fixed the auto rotate issues. Safari seems to run in a special sandbox, so it still doesn't rotate. Updated the Pandora home button to bookmark on double tap (just keep pressing the bookmark button quickly a bunch of times). The AppRadio app is now killed when you unplug the cable. Added the Home button to the AppRadio app menu. I still don't know what's causing the resize issue. The triangles on the sides of the app is actually the ends of the AppRadio app dock across the bottom. I'm thinking it's a problem with overscan but everything I tried hasn't worked yet. Link to post Share on other sites
saiojitsu Posted June 10, 2013 Report Share Posted June 10, 2013 Where's this update??? Link to post Share on other sites
VBLUE42 Posted June 10, 2013 Report Share Posted June 10, 2013 In Cydia and the first post of this thread. Link to post Share on other sites
verso Posted June 10, 2013 Report Share Posted June 10, 2013 Hi. mikedecaro, great job. Thank you. For the new version Appradio (https://itunes.apple.com/us/app/appradio/id434811742?mt=8) and iOS 5 will support?Sorry, the Google translation. Link to post Share on other sites
WRS Posted June 10, 2013 Report Share Posted June 10, 2013 Just posted an update: Fixed the auto rotate issues. Safari seems to run in a special sandbox, so it still doesn't rotate. Updated the Pandora home button to bookmark on double tap (just keep pressing the bookmark button quickly a bunch of times). The AppRadio app is now killed when you unplug the cable. Added the Home button to the AppRadio app menu. I still don't know what's causing the resize issue. The triangles on the sides of the app is actually the ends of the AppRadio app dock across the bottom. I'm thinking it's a problem with overscan but everything I tried hasn't worked yet. Thanks Mike. Any more thoughts on mirroring apps like Pandora? Link to post Share on other sites
