angelgps Posted July 9, 2012 Report Share Posted July 9, 2012 Hello, I have an AVIC F500BT, and I downloaded the firmware update 4.0 on the pioneer site, since then, the version 4001000 2007000 replaced the original version, but the map disappeared, and when I check the settings, informs THE MAP VERSION (as map was not installed at all, please someone help me? I have entered THE TEST MODE AND PASTE MY FLASH/LPUE080/APL2/ IGO / CONTENT / NO MAP IS NO FOLDER THERE IS ONLY THE FOLDERS: LANG, SCHEME AND TMC. THANK YOU!!! Quote Link to post Share on other sites
tail24 Posted July 10, 2012 Report Share Posted July 10, 2012 do you have a back up? Quote Link to post Share on other sites
angelgps Posted July 10, 2012 Author Report Share Posted July 10, 2012 hello I have no backup of the old version (2:007000), for the 4:001000 version of the SD card installed automatically replacing the previous one, the update has completed, the problem is that the map is gone. Please how can I do to install this map F500BT? Quote Link to post Share on other sites
tail24 Posted July 11, 2012 Report Share Posted July 11, 2012 I'm not that familiar with the f500bt but if it's an official firmware you uploaded purchased via pioneer you should call and ask why this oils happen. They should be able send you a proper update. Quote Link to post Share on other sites
angelgps Posted July 12, 2012 Author Report Share Posted July 12, 2012 Hello, please does anyone know how to manually install IGO? since the firmware update 4.0 not installed map. Quote Link to post Share on other sites
tail24 Posted July 12, 2012 Report Share Posted July 12, 2012 It's because 4.0 doesn't have maps in it. Did you buy an official copy if so from where? Quote Link to post Share on other sites
angelgps Posted July 14, 2012 Author Report Share Posted July 14, 2012 hi, since we do not have maps in version 4.0, how can I do to instal a map? and what map? please help me, I'm from Brazil, and pioneer of Brazil does not support this type of gps. Thank you! Quote Link to post Share on other sites
pionara Posted July 17, 2012 Report Share Posted July 17, 2012 i suspect you did something outside of downloading the update and allowing pioneer to update normally. If you are using 4.x sw without having upgraded with CNSD-200FM properly, then you will need to obtain official maps somewhere, or most likely: 1. find igo8.3 compatible maps/pois and drop them in the content folder 2. find "patched" igo (aka ezrider.exe) along with "unrestricted" igo licenses.. search around the forum for posts by "carver" Quote Link to post Share on other sites
tail24 Posted July 17, 2012 Report Share Posted July 17, 2012 The issue is I think he will struggle with finding igo south america. His ezrider should already be patched and correct license files on it. But Ubless you have a backup of your avid before you modded it nothing can be done. Have to have brazil maps in hand. Quote Link to post Share on other sites
pitbull Posted January 6, 2013 Report Share Posted January 6, 2013 yo eh encontrado esto pero no se si servira para el F500BT ami me a pasado lo mismo http://www.htcmania.com/showthread.php?t=431764 Quote Link to post Share on other sites
urtruelove78 Posted July 6, 2013 Report Share Posted July 6, 2013 Firmware 4.0 is not compatible with f500bt. Even if you manually put maps files in it. It will not respond after you reboot unit. If anyone successfully updated f500bt with 4.0 firmware then give us steps. Quote Link to post Share on other sites
